Oil accumulator questions?
Old Aug 22, 2006 | 10:39 AM
bdc95ta's Avatar
Did a search but was hoping for a little more info. w/ those that have run them.
-Are these reliable enough to run in a street car?
-Do the o-rings need to be replaced, often?
-Are certain brands better than others?
-Where are you pluming yours? I saw on accusump's website that they have a kit for our car's has anyone used it?
-Should I get the 2qt one or 3qt? Where are ya'll mounting yours?
-What kind of valve should I get (electric, manual)?
The car's going to be a daily driver/roadracer car that's why I'm seriously considering this.
thanks,
brandon
Old Aug 23, 2006 | 05:50 AM
ZBLKHELLRZR's Avatar
Re: Oil accumulator questions?
thanks,
brandon
Matter of preference
1. Yes
2. No
3. Plump to relocation kit and the sump mounted up front of the IC or you can mount it in front of the radiator as long as it's not the 3 qt sump
4/5. I did electric and hot wired so I have + oil pressure before the car cranks
Old Aug 23, 2006 | 07:46 AM
1racerdude's Avatar
2qt will be iffy as to cold starts. I was looking at a 1gal one but mounting it would have been a *itch. Ya got to have enough oil to completely oil the engine for it to be of intended value.
I was looking at the Canton unit but decided on another way.Roller cam brgs and coated brgs for street/drag.
Old Aug 23, 2006 | 08:14 AM
I'm running a 3qt. I didn't have luck w/ my last set of coated bearings so I shy away from them and went this route instead.
Old Aug 23, 2006 | 08:22 AM
1racerdude's Avatar
Well if this don't work I will go dry sump then guaranteed NO problems even up side down.
Old Aug 23, 2006 | 08:29 AM
I thought about that but didn't know what was all required to do it. THAT is the best route hands down w/ a dry sump.
Old Aug 23, 2006 | 08:40 AM
1racerdude's Avatar
Mostly money is required.
Ya need a tank,pump,pan and lines,and a place to put it all.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
