Ohm readings for O2 and Knock sensor wires
Old Nov 1, 2005 | 10:27 AM
Casey_SS's Avatar
Anyone know what the ohm readings should be when measuring the wires between the PCM and the sensors? I need to add about 4 feet of wire to reroute my harness away from the headers and want to make sure the extra wire doesn't add too much resistance and interfere with the signals the PCM receives.
Anyone have experience doing this type of thing? Kinda surprised that nobody else seems to have had my issues with headers being too close to the stock wiring locations....(do a search on my username if you want the long, gritty saga)
Thanks.
Old Nov 1, 2005 | 10:33 AM
Dave89IROC's Avatar
Re: Ohm readings for O2 and Knock sensor wires
as low as possible(under 5 ohms maybe?)ohm them out before moding, and check after, as long as it is stays about the same you should be fine, make sure you solder and heatshrink the connections you make
Old Nov 1, 2005 | 04:43 PM
Sensor resistance should be between 3300-4500 ohms (OBD-I) or 93k-107k ohms (OBD-II). The wire should not add any appreciable resistance. Keep it in the range shown and you should be ok.
Old Nov 2, 2005 | 05:08 AM
Guest47904's Avatar
Guest
We either did have an issue that you mentioned or like me, simply bought the extensions I posted in your other thread and used zip ties to eliminate the problem from ever happening in the first place. I posted the longer of the 3 Casper offers but I used the 24 inch ones.
Your posts would be easier to follow if you continued with the same one and not start new ones.
HectorM52
Jul 30, 2017 11:46 AM
squarehead
Jan 15, 2015 07:02 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Omega9
Aug 2, 2002 12:33 AM
