Ohio Cranks any good?
Old Dec 3, 2009 | 09:21 AM
kgkern01's Avatar
I am getting my parts list together for my 385 stroker. I am going forged due to using high compression (~14:1) and E85, but will never go power adder with boost or spray, and keep the RPM's sub 68-6900. I already have SRP pistons, and will use Scat I-beams.
I see that Ohio Crank has some cheap priced forged cranks, and was looking at the 5140 forged crank as a possible option. Does anyone have any experience with these, I would like to keep costs down on this build if I can.
Old Dec 3, 2009 | 09:39 AM
bombebomb's Avatar
From what I have Heard they are good cranks, but wait for some others to chime in.
Old Dec 3, 2009 | 12:29 PM
camaroz28383's Avatar
If your turning 68-6900 rpm with 14:1 compression i would not go 5140 I would go 4340 fo the added strenght because 5140 cranks usually arnt rated for much over a cast crank and I have not heard of a single failure of an Ohio crank. scat I beams might not be up to the task for a build like yours
Old Dec 3, 2009 | 12:34 PM
mknabz28's Avatar
Id suggest going with H-beams
Old Dec 3, 2009 | 01:01 PM
93BlackTA's Avatar
PM Sent
Old Dec 3, 2009 | 01:20 PM
marshall93z's Avatar
A couple years ago, their quality control was HORRIBLE. Sizing was way off, journals tapered badly. A lot of them needed a LOT of heavy metal to balance right.
For cheap forged stuff, I would probably stick with SCAT or Eagle. And hell, even their QC isn't good.(At least my crank wasn't ).
Do a lot of measuring on whatever piece you buy.
Old Dec 3, 2009 | 01:24 PM
kgkern01's Avatar
Well the pistons I have are for 5.7 rods, the Scat Pro-comp rods should be strong enough, the RPM will probably be under 6800, as is mostly a street car with occasional road course/autox.
I was curious about the 5140 crank if it would be strong enough, the 4340 is not much more expensive if it is necessary.
Old Dec 3, 2009 | 04:30 PM
rskrause's Avatar
Moderator
If you are buying a lower end offshore crank, SCAT is definitely the one to consider.
Rich
Old Dec 3, 2009 | 10:10 PM
SS MPSTR's Avatar
Lots of big HP guys running them.
Old Dec 3, 2009 | 10:42 PM
Probably with a lot of work in them. lol
Old Dec 3, 2009 | 10:51 PM
bombebomb's Avatar
Apparently things have really turned around there and they have really got the ball rolling.
Old Dec 4, 2009 | 01:17 AM
Wooshie's Avatar
I have heard lots of good things about them and will be using one in my next build.
Old Dec 4, 2009 | 01:27 AM
If that's true, then it's good to hear!
Old Dec 5, 2009 | 06:58 AM
RamAir95TA's Avatar
I have an Ohio crankshaft in my current motor. Came highly recommended by my builder. No complaints or problems.
dale3in98
Feb 14, 2015 12:18 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
