oh my god... im about to jump off a bridge
Old Apr 29, 2003 | 11:15 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
ok so as some of you remember... im having serious tranny problems... it won't shift out of second.... yada yada yada
im in a major hurry... if you want some history on this.... just search for the thread that starts with "oh sweet jesus"... anyway so im still driving my car figuring i can't hurt my tranny any more since i already need a new one im just milking it for all its worth...
anyway this is whats wrong... im driving the car home tonight and it starts making this grinding vibrating sound... and i just figure that the tranny is finally blowing for good and that i new this would happen... but the car still is going fine and all... i can't figure it out... it sounds/feels like the trans. but the rpms are fine they go up and down smooth with no problems... and all kinds of other stuff like that
this is whats weird: when i turn the wheel right (while basically going straight) the grinding sound gets much worse...
and when i turn it left it ALMOST goes away... the same is true when i hit the brakes fairly hard... no matter what speed i am going... this is all making me think that this grinding isn't coming from the tranny
and ideas would be SUPREMELY appreciated...
Old Apr 29, 2003 | 11:17 PM
frmula1's Avatar
edit: its when i turn the wheel left when it gets worse... not right...
Old Apr 29, 2003 | 11:51 PM
frmula1's Avatar
see i can't put it into 1 cause its an auto... and im not gonna have it rebuilt... just gonna replace it.... will i need a new torque converter too?
Old Apr 30, 2003 | 12:19 AM
1994CamaroZ28's Avatar
i paid 1244 for my tranny 3 year 50k mile warrenty free parts service or replacement.
Old Apr 30, 2003 | 12:36 AM
BPS's Avatar
BPS
sounds like a bad wheel bearing
Old Apr 30, 2003 | 12:41 AM
chesee48's Avatar
What bridge? golden state bridge?
Old Apr 30, 2003 | 09:57 AM
frmula1's Avatar
bad wheel bearing huh? thats interesting... because i had just taken off the wheels to throughly clean them... anything i may have screwed up by putting them back on that would be causeing this ???
Old Apr 30, 2003 | 10:21 AM
Rog's Avatar
Rog
I would guess a wheel bearing/hub also if the grinding goes away when turning and or braking. Does the grinding sound vary with speed instead of RPM? Since the sound goes away when you turn left, check the right side bearing.
Old Apr 30, 2003 | 10:35 AM
frmula1's Avatar
yes, its speed oriented not rpm.... which is what originally led me to believe it wasn't the tranny... i edited... it goes almost away when i turn the wheel slighty right... so i'll have the left checked... what about my tranny problems... do i just need a solenoid?
Old Apr 30, 2003 | 01:41 PM
C Man's Avatar
I'd suggest not driving the car. If your tranny "blows up", all the fragments will pass into your torque converter as well. I'm assuming it's still fine.
Replace the tranny before you do more damage.
Old Apr 30, 2003 | 02:02 PM
Tech's Avatar
Can I have your car if you jump?
Old Apr 30, 2003 | 02:07 PM
frmula1's Avatar
no, well yes... i've always told my friends... if i were to die it would probably be IN my car... therefore not leaving much left... but you can have whats unclaimed...
PopoFormula
Oct 12, 2015 04:19 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
tdigger9899
Sep 7, 2015 10:56 AM
jerrysims71
Aug 15, 2015 12:47 PM
