Oh crap......put dash in and speedo doesn't work?!?!
Old Jan 14, 2004 | 10:13 PM
notstock4long's Avatar
Hey guys, got a quick question. I removed my dash to paint it, and now I have everything back together, but the speedometer doesn't work. Everything else does though, tach, temp, oil pres, voltmeter.
Did I forgot to hook something up, like is there a seperate wire for the speedo?
Also, when I had it out, it somehow got up to 160mph or however high it goes, so I held it seideways till it went back to 0. Does this have anything to do with my problem? Thanks
Old Jan 15, 2004 | 06:40 AM
snake_skinner93's Avatar
check the speedo needle. it could've jumped off a bit. i took my cluster out to install white face guages on my old 93 Z and when i put the cluster back in and went down the road, i noticed my speedo didnt move at all. took the cluster back out and the needle was slightly out. i pushed it back in wih some force and it was ll back to normal. good luck.
Old Jan 15, 2004 | 11:12 AM
I might try that, but I never actually had the cover off the gauges, but maybe it just got knocked loose from floating around the garage for a while.
I could only get up to about 10mph to try it out, since the car was still in the garage. Any other ideas?
blac94Z
Feb 10, 2015 11:02 AM
mr28
Nov 23, 2014 11:11 AM
Jul 4, 2005 05:00 PM
Evilfrog
Aug 7, 2002 11:36 PM
Snake Slayer
Jul 26, 2002 06:14 AM
