offroad pipe question
Old Feb 24, 2004 | 12:37 PM
Rocks94z28's Avatar
if i put a pipe in place of my cat what do i do with the sensor that plugs into the cat?
thanks,
Jesse
i do the emissions thing so i have no worries there,
Old Feb 24, 2004 | 12:43 PM
LPEdave's Avatar
I can't envision the '94 right here, but you've got an O2 sensor that plugs in upstream of the cat. It still needs to be there if you remove the cat.
Dave
Old Feb 24, 2004 | 12:49 PM
ppmz28's Avatar
I am not possitive but i have a 94 and the o2 sensors are in front of the cat(you have the 1 cat system) and the o2 sensors will not be affected by removing the cat. No service engine soon light should come on either.
Old Feb 24, 2004 | 01:29 PM
ibanez6rg's Avatar
Sensor that plugs into cat?
Old Feb 24, 2004 | 01:32 PM
gamecockfan04's Avatar
On the 94's there isnt anything that plugs into the cat. There are 2 O2 sensors, one on each side of the Y pipe, but that should be it. Are you changing the Y pipe as well?
Old Feb 24, 2004 | 01:35 PM
teke184's Avatar
my first thought was ....there isn't anything that plugs into the cat...
then i was thinking...do the 94's have an air tube that goes into the cat? or was that eliminated by the air tubes on the manifolds?
i know my 87 iroc had an air tube ON the cat...just a thought...
Old Feb 24, 2004 | 01:39 PM
ibanez6rg's Avatar
Nope.
Old Feb 24, 2004 | 01:40 PM
Not unless its an aftermarket cat. Most of the aftermarket/universal cats have the air tube, but you can just cap them if you dont need it.
Old Feb 25, 2004 | 12:49 PM
Rocks94z28's Avatar
i'm dumb i was mistaken,
got everything worked out,
thanks, sorry for the trouble
97bowtie
Aug 25, 2002 11:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Camaro90RS
Jul 23, 2002 07:57 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
