OEM vs. Aftermarket Fuel Pump
Old Jun 26, 2003 | 03:08 PM
MikeyNutt's Avatar
My fuel pump is starting to go and I was hoping to go with a racetronix or walboro Fuel Pump.
I did a search and I read here and there about the install.
Unfortunately I don't have the time so I was wondering how hard is the install and soemthing about the "fuel bucket"??
If I get the OEM Pump, it's a direct exchange, so it's nice and simple.
Is that much of a diffrence??
Also, where can I find good prices on the fuel pumps??
THANKS!!!
Old Jun 26, 2003 | 03:14 PM
EvlViln's Avatar
Tunedbytad.com
There is a video there of how to install a fuel pump into an f-body.
Go Walbro, I did And it provides much better pressure and is a higher volume. Also it's cheaper than the OEM. The OEM @ my local dealer was over $200, I think I paid $110 including shipping & tax for my Walbro.
hope this helps.
Old Jun 26, 2003 | 03:19 PM
FacelessZ's Avatar
Is a fuel pump even necessary for 30# injectors? That's what I'm planning on going with and was just curious....
I believe that the stock pump will work fine for the 30#'ers but I just want to make sure...
Old Jun 26, 2003 | 04:27 PM
tkatchev69's Avatar
I'm also curious about OEM fuel pump with 30# injectors. Anyone have opinions?
Old Jun 26, 2003 | 04:30 PM
FacelessZ's Avatar
nice mileage tkat...
Old Jun 26, 2003 | 04:51 PM
tkatchev69's Avatar
Oops, I forgot to change the mileage this afternoon. Turned over 212,000 miles on teh way home from the base. Thanks for noticing!
Old Jun 26, 2003 | 05:27 PM
FacelessZ's Avatar
Anyone? Stock fuel pump good with 30# injectors?
Old Jun 26, 2003 | 08:52 PM
EvlViln's Avatar
IMO- the stock fuel pump isnt enough for even the stock injectors! Change it out, especially if you have over 100K on the car!
Old one has done its duty, time for a new high volume/pressure unit. Oh and done forget the adjustable fuel pressure regulator (if you dont already have one that is).
Once again just my opinion!
Old Jun 27, 2003 | 02:37 AM
Racetronix's Avatar
http://web.camaross.com/forums/showt...ght=racetronix
http://www.racetronix.com/Racetronix..._Pump_Kit.html
The 255L high pressure pump assembly is available for $149.99 as well.
Thunder Racing should have more in stock (soon).
cmyname1
Feb 19, 2015 08:38 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
