OE Oil Pump = m-55 or m-155
Old Apr 22, 2011 | 11:19 PM
aaron_depue's Avatar
Going back to a OE style standard volume oil pump and pick up. Which one of these 2 oil pump is a OE factory replacement for my 94 Z? Im going to pick one up from AutoZone. Its a Melling unit, but I didnt know which one of these 2 pumps was the one I needed.
m - 155 - 3/4 screen inlet
m -55 - 5/8 screen inlet
Old Apr 22, 2011 | 11:38 PM
Re: OE Oil Pump = m-55 or m-155
They changed from 5/8" to 3/4" during the 94 year. I'd just go with the 3/4". But...I would get a Melling Select 10554 instead. It is a better/stronger casting than the M series and it comes with a steel collared drive shaft and 70# spring you can install.
Old Apr 23, 2011 | 07:20 AM
3/4 inlet? Is that the same size inlet that a HV pump would have. I have the oil pickup from the HV pump. Wonder if it will size up?
I noticed there is an high pressure spring option. Good idea? Any draw backs?
Old Apr 23, 2011 | 08:44 AM
There might be 5/8 HV pumps but that does not matter. I always use a new pickup. Use the high pressure spring. No drawbacks.
Old Apr 23, 2011 | 01:02 PM
does the melling performance oi pump come with that 70lb spring or is it purchased seperately?
Old Apr 23, 2011 | 01:32 PM
I think I already answered that. It comes with a standard and 70# spring.
Old Apr 23, 2011 | 02:32 PM
MachinistOne's Avatar
Just FYI, Melling has gone back to the older heavy duty casting on their oil pumps, for the last 8 months or so all the M-55A pumps which we use on most builds have been the HD casting. The steel collared pump drive part on it's own is a part # IS-55E
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
