Odd problem car wont quit cranking
Old Apr 1, 2004 | 11:15 PM
THEMADTYPH00N's Avatar
I just got done with a Longtube install. I got everything together but as soon as I go to hook up the battery the car start cranking. It never starts because the key isnt turned. As soon as I take off the battery cable it stops. Any ideas?
Old Apr 1, 2004 | 11:19 PM
88RX7LT1's Avatar
You miswired the starter.
You have two posts and a solenoid; figure it out. If you can't, pm and we'll fix it together.
Old Apr 1, 2004 | 11:27 PM
i dont think its misswired, there are 2 posts. one big one with the power from the battery and a smaller one for the ignition wire, they are both hooked up correctly. im beginning to think the solenoid itself is grounding out internally
Old Apr 2, 2004 | 12:14 AM
Found the problem. The soleniod must have stuck. I smacked it a few times with a hammer and it acted normally.
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Nov 25, 2014 11:20 AM
USAirman93
Nov 24, 2014 03:37 PM
1LEThumper
Jul 14, 2003 12:45 PM
GigaMp3z
Feb 20, 2003 02:57 PM
