ODBII code question
Old Nov 13, 2002 | 11:33 PM
SS1304's Avatar
ODBII code question
Hey guys i'm kinda a newb here but around the other boards. My car threw a code today twice I auto taped it and this is what it threw
P1441 EVAP System Flow During Non-Purge
What is this and how do i fix it?
Thanks, Leroy
Old Nov 14, 2002 | 12:53 AM
MattysTA's Avatar
seems to me that the evaporator canister was alowing flow through it when it wasnt supposed to. as for fixing it im not sure. sorry i cant help you more....
Old Nov 14, 2002 | 01:11 AM
The purge solenoid is on a bracket on the passenger side of the intake manifold. There is a hose that goes to a vacuum sensor on the side of the engine, and from there into the connection on the side of the throttle body. If you are getting flow during non-purge, could be the solenoid is stuck open, there is a leak in one of the hoses between the solenoid and the throttle body, or the vacuum sensor is bad. I have also seen a few posts in the past where all of this was replaced and didn't solve the problem....
Old Nov 14, 2002 | 01:17 AM
ixd97z28's Avatar
hehehehe I have that same code!
http://web.camaross.com/forums/showt...&postid=306908
My thread about the same thing....
Old Nov 14, 2002 | 11:35 AM
SS1304's Avatar
I did some looking and found it could be the charcol can dunno????
Old May 25, 2003 | 12:29 AM
Commando413's Avatar
p1441 code
I've been having trouble with the p1441 code too. i changed the canister and it did nothing except make the code wait longer before coming on again. talk about mifted. anyway my next course of action is to change the solenoid and the valve and hope for the best
Old May 25, 2003 | 12:51 AM
The code is for "Flow During Non-Purge." It is extremely unlikely that the cannister would cause that problem, so replacing it wasn't the best thing to do. Read my previous answer.
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
johnsocal
Aug 29, 2002 10:01 AM
91Bird305
Aug 5, 2002 01:39 PM
