OBDII Scanner software???
Old Jan 7, 2005 | 01:27 PM
96 WS6's Avatar
I have freescan and a cable. Can I scan an OBDII car for SES codes and clear them? That's all I need to do, and I think I remember scanning my car before I swapped the OBDI computer in it.
Anybody know this one?
Old Jan 7, 2005 | 01:30 PM
96capricemgr's Avatar
Re: OBDII Scanner software???
Freescan will not do OBD2. The cheapest solution I know of for OBD2 is Harbor Freight offers a scanner for $40 I believe all it does is trouble codes not live data like freescan can.
Old Jan 7, 2005 | 04:07 PM
Makaveli's Avatar
if you have an OBDI computer in there, then cant you still scan it with the cable and freescan? did you mean you have the OBDI conversion?
Old Jan 8, 2005 | 12:56 PM
96 WS6's Avatar
Can I clear the codes by pulling the PCM fuse or disconnecting the battery then?
Old Jan 8, 2005 | 01:19 PM
Eff's Avatar
Eff
Just unplug the negative battery terminal for 5 minutes. That will clear it
You can also buy a scanner that will pull and clear obdII codes for 28 bucks at autozone
Old Jan 8, 2005 | 01:42 PM
stereomandan's Avatar
See this:
http://web.camaross.com/forums/showt...obdii+scanning
Dan
Old Jan 8, 2005 | 01:55 PM
Originally Posted by stereomandan
Be careful with that one... the info is almost 2 years old, and many of the Model #'s and links are outdated. Things change so fast I can't find enough time to update the writeup.
Old Jan 8, 2005 | 02:17 PM
I find it easier to remove the PCM BAT fuse for about 30 seconds and it does not bother your radio presets.
Old Jan 8, 2005 | 02:32 PM
O.k. Sounds good. Thanks for the warning.
Dan
Old Jan 8, 2005 | 07:39 PM
Dan Parker '96's Avatar
Try www.obd-2.com or www.efilive.com
EFI Live OBDII version 5 is really for the LS1 engine but works wonderfully well for almost all the LT1/4 parameters (I haven't got the version 6 to work properly yet). The interface is wonderful.
The OBD2 software will log practically all OBDII equipped cars with most manufacturer specific functions as well. The interface is not as pretty but works great.
I use both along with LT1 Edit.
Old Jan 9, 2005 | 12:00 PM
Eff's Avatar
Eff
hmmmmm. never thought of that one.....
Good call.
Nayr
Mar 3, 2023 08:34 PM
MDZ28
11
Sep 24, 2015 09:15 AM
plattted
9
Sep 20, 2015 11:23 AM
98-LS1Z28
Sep 8, 2015 03:12 PM
ZXXVIII
Sep 1, 2015 10:13 PM
