OBDII Scanner/ Scan tool
Old May 21, 2005 | 08:07 PM
matt65's Avatar
I am in the market for a scanner to pull the codes from my 97. What is a good brand? Are these cheaper <50$ tools worth getting? Least expensive route to figure out why my SES light is always on, and fix the problem.
Thanks,
Old May 21, 2005 | 08:49 PM
5.7LT1Formula's Avatar
Re: OBDII Scanner/ Scan tool
i use FreeScan. its Free...you just need cables and a laptop. google it and i'm sure you can find a download.
Old May 21, 2005 | 09:07 PM
matt65's Avatar
Is there any risk of damaging the pcm? When scanning with cable and laptop?
Also My search on freescan I found that:
"Please Note: FreeScan is not OBD-II compliant. It will only work on the vehicles listed below."
Old May 21, 2005 | 09:19 PM
moparman's Avatar
If you only want an OBDII code puller, the cheapest one I've seen is sold by Harbor Freight Tools. It's under $50. It is not a scan tool, only a code retreiver.
Old May 21, 2005 | 09:28 PM
Dwaynez28's Avatar
Smile Re: OBDII Scanner/ Scan tool
If you just want to pull a couple of codes, i think AutoZone still pulls codes for free. Dwayne
Old May 21, 2005 | 09:57 PM
Jon 97TA's Avatar
There's no risk when scanning. AFAIK the only risk you have to worry about is when you're reflashing the pcm.
yup.
Old May 22, 2005 | 01:10 AM
Last time I checked the freescan website, they still hadn't released the OBD-II version. Is it available now?
marlar98
Sep 12, 2018 07:18 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
KYWes
Sep 26, 2015 08:49 AM
plattted
9
Sep 20, 2015 11:23 AM
tommalcolm
Sep 11, 2015 03:39 PM
