Obd2-obd1 cps
Old Nov 2, 2010 | 09:49 AM
TT350's Avatar
Obd2-obd1 cps
Ok guys what I would like to do.
I have a 96 T/A and I would like to convert it to OBD1.
It is my understanding that I need a 16188051 PCM.
This is the 94-95 OBD1 PCM.
My question is my 96 has a crank position sensor
and it is my understanding that the 94-95 OBD1 cars do not have a CPS.
I know it will work because I read about the swap all the time but this is never mentioned.
What do I do with the CPS?
Leave it plugged up or unplug it?
I plan on using TunerCat to tune with after the swap
FYI.
Thanks for your time
Chris
Old Nov 2, 2010 | 10:58 AM
Re: Obd2-obd1 cps
You don't have to do anything with the sensor. The OBD-I PCM will not know it is even there and won't care that it is. You can just leave it be.
Old Nov 2, 2010 | 11:30 AM
TT350's Avatar
Re: Obd2-obd1 cps
Thanks!
Old Nov 2, 2010 | 07:35 PM
TT350's Avatar
Re: Obd2-obd1 cps
http://chevythunder.com/lt1_electrical_page.htm This site is saying that the 16188051 ECM come with different knock sensor modules.
Depending on the module it could be set up for dual or single knock sensors.
http://carputing.tripod.com/OBDII_to...Conversion.htm
This site is saying to just use the knock sensor part# 10456126
with no mention of a module # other than the LT4 if you what to
run the LT4 module and sensor.
My ECM Knock sensor module part # is 16188309.
According the first site link I posted I have a dual knock sensor
module.
The #'s on my module appear like this on the module.
The top # matches one listed on the site.
The bottom don't come up anywhere but I'm posting it
if some one needs it to help me.
16188309
1084139
What knock sensor part# do I need, dual or single?
Chris
Old Nov 2, 2010 | 08:06 PM
TT350's Avatar
Re: Obd2-obd1 cps
Never mind I found it. https://www.camaroz28.com/forums/sho...d.php?t=369149
This site is the **** megee!!
markzzzz
May 8, 2015 09:21 AM
Steves396lt1
Jul 21, 2005 10:40 AM
96birdlt1
Sep 13, 2004 06:23 PM
AronZ28
Jun 13, 2004 05:13 PM
AronZ28
Jun 8, 2004 08:51 PM
