OBD1 SES Problem
Old Jun 27, 2004 | 02:18 AM
99BlackTA's Avatar
OBD1 SES Problem
I have a 1994 pontiac trans am and my SES light keeps coming on for a while but then turns off. I have tried to test it and when I put the tested in the harness the electric fans turn on and the SES light flashes WAY too fast to read it. My electric fans keep on turning on driving around even when it isn't hot. What could be the problem?
Old Jun 27, 2004 | 02:33 AM
DonHood's Avatar
Re: OBD1 SES Problem
You can only do the "jumper" trick if you have a 93 f-bod. 94 and up you have to use a diagnostic scanner of some kind.
Old Jun 27, 2004 | 08:30 AM
If it comes and goes, a good bet it is EGR related. Your fans will come on when the SES does, that's normal. As stated, you will need a scan tool to tell you what the code really is.
Old Jun 27, 2004 | 01:56 PM
jeepbeast's Avatar
if i blocked my egr tube on the back of the manifold when i did my headers, would that cause the ses to come on? i havent had the egr programmed out yet.
Old Jun 27, 2004 | 03:07 PM
OBD-I is usually not as sensitive as far as the EGR goes and it takes a certain amount of time driving in certain conditions to set it off. If you don't get the SES, don't sweat it.
Old Jun 28, 2004 | 08:19 AM
jeepbeast's Avatar
well, just as you said it, my ses went off. since the computer will store this code, will it hurt performance? should i just clear the codes before going to the strip?
Old Jun 28, 2004 | 11:32 AM
"Stored" codes don't cause the PCM to make any changes. Its just "stored" so you can retrieve it in the near future. Eventually, the codes will clear themselve from memory, but they don't affect anyhting being stored there.
If you "clear" the codes by pulling the PCM power, you will also be clearing the long term fuel corrections, and that might affect performance.
Old Jun 28, 2004 | 12:15 PM
Jay-Roll's Avatar
I have the intermitten SES light and I also thought it was the EGR. Turns out my AIR pump was seized up and that was causing the issue. I would be off when the car was started but then turn on after I drove for awhile. Turn off when I was sitting at a stoplight. Then come back on as I started to go. Haven't resolved it yet, but I'm just getting it tuned out and removing it from the car when I do the LT install.
Old Jun 30, 2004 | 12:05 AM
99BlackTA's Avatar
When the SES light comes on the car kinda feels like it stumbles and I also noticed that today it made some loud pinging a couple of times. What different things could cause this other than the 02 sensor? I mean things that will trip the computer code too.
Old Jun 30, 2004 | 12:10 AM
You really need to find out the code for the SES. Again, it could be the EGR, since one of it's functions is to lower combustion temperatures. Too high combustion temps could cause detonation (pinging).
Old Jun 30, 2004 | 12:11 AM
99BlackTA's Avatar
The light never stays on. Everytime I go and get it tested it isn't on but as soon as I leave the damn thing pops back on for a bit.
Old Jun 30, 2004 | 10:08 AM
But the code is stored, even if the light isn't on. ??????
What are they trying to scan it with?
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
greenzee28
Mar 26, 2015 09:13 AM
nikolt1
Feb 27, 2015 09:10 PM
Gtpguy
Jan 26, 2015 04:50 PM
