OBD1 SES Problem
OBD1 SES Problem
I have a 1994 pontiac trans am and my SES light keeps coming on for a while but then turns off. I have tried to test it and when I put the tested in the harness the electric fans turn on and the SES light flashes WAY too fast to read it. My electric fans keep on turning on driving around even when it isn't hot. What could be the problem?
Re: OBD1 SES Problem
Originally posted by jeepbeast
if i blocked my egr tube on the back of the manifold when i did my headers, would that cause the ses to come on? i havent had the egr programmed out yet.
"Stored" codes don't cause the PCM to make any changes. Its just "stored" so you can retrieve it in the near future. Eventually, the codes will clear themselve from memory, but they don't affect anyhting being stored there.
If you "clear" the codes by pulling the PCM power, you will also be clearing the long term fuel corrections, and that might affect performance.
I have the intermitten SES light and I also thought it was the EGR. Turns out my AIR pump was seized up and that was causing the issue. I would be off when the car was started but then turn on after I drove for awhile. Turn off when I was sitting at a stoplight. Then come back on as I started to go. Haven't resolved it yet, but I'm just getting it tuned out and removing it from the car when I do the LT install.
When the SES light comes on the car kinda feels like it stumbles and I also noticed that today it made some loud pinging a couple of times. What different things could cause this other than the 02 sensor? I mean things that will trip the computer code too.
The light never stays on. Everytime I go and get it tested it isn't on but as soon as I leave the damn thing pops back on for a bit.
What are they trying to scan it with?
oldschool
Feb 9, 2016 09:21 PM
Gtpguy
Jan 26, 2015 04:50 PM
