OBD1 conversion and emissions. What do you guys do?
Old Nov 22, 2006 | 08:03 AM
Acct 23749's Avatar
Well, when I did the OBD1 conversion on my '97 years ago in FL, there were no emissions inspections. Now living in NM, they need to scan all OBD2 cars to check for codes....simpl, if you OBD2
Of course the OBD1 computer wont scan as an OBD2 and thus you cant ever pass.... What do you guys do?
Old Dec 1, 2006 | 05:59 PM
Acct 23749's Avatar
Guess im the only one
Old Dec 1, 2006 | 06:13 PM
JP95ZM6's Avatar
Wink
Mabye stick a $100 bill in the OBD connector?
Old Dec 1, 2006 | 06:26 PM
SevenStars's Avatar
LMAO, I kinda like that idea... I wonder if it will work if I tape one where my cars cat should be for NY's emission inspections?
Old Dec 1, 2006 | 06:40 PM
Acct 23749's Avatar
I think i finally got a hookup...gunna try to scan someone else maro...well will see....just hate being devious. If i have an OBD2 i would pass no problem
Old Dec 2, 2006 | 10:44 AM
Severous01's Avatar
get an obd2 ecm and hook it up in the parkin lot. or right before you go. i'll be doing the ecm swap soon too and i'm keeping my obd2 ecm for that particular reason. now i'm military so i dont have state emissions but sooner or later i may have to register legally.
Old Dec 2, 2006 | 11:01 AM
truedualws6's Avatar
What I do
I have an OBDII PCM that is tuned and set up to use for emmissions with
the exception that it ignores the KS. I just swap the PCM for emmissions
testing and drive the car carefully since there is no functioning KS. It worked
fine last time and I passed. You can also search for my post on the topic.
You also must make sure the minimum OBDII driving cycle states are set in
the PCM. You can search on this too or go to www.obdii.com
Old Dec 2, 2006 | 11:12 AM
Acct 23749's Avatar
If i threw a OBD2 pcm in there i doubt my car would even run, much less not throw any codes. When i did the swap i dont even think OBDII edit was even out yet, that or the price was rediculous.
But maybe thats something i should look into now, getting OBD2 edit and and OBD2 PCM.
Next question is though:
1. can you transfer a OBD1 LT1edit program over to OBD2 lt1 edit? I guess you can just open them side by side if you cant.
2. Does the emmissions computer check the PCM for a vin?? if so, i have no clue how to track down my Original PCM...i sold it 2 years ago to member wolf or wolfpunk something like that.
Old Dec 2, 2006 | 02:45 PM
Obdii Pcm
I had all this done with Jeff Creech when he was out in SoCal during a
dyno day. The OBDII PCM was dyno tuned and Jeff just made the program
changes necessary for me to use it for emmissions. I'm don't know much
about this stuff and leave it to the pros.
I don't think it matters what OBDII PCM you have. I have two of each just
in case I need to mail one to Jeff. The PCM that I use for smog is not the
original from my car. I have the original, but it's programmed to work with
the 97 KS in case I have to put it in longer term.
HectorM52
Jul 30, 2017 11:46 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Queens94z28
Dec 20, 2014 09:11 PM
Red97LT1
Aug 7, 2002 05:45 PM
