OBD1 Computer Question
Old Jul 8, 2003 | 02:42 PM
LT1CST's Avatar
OK I need some Computer NUTS in here. LOL
I gotta 94 LT1. with the Obd1. Im getting a Camshaft put in the car. THASS IT. I did a full rebuild. I DID NOT change the Cubic Inches. OF the motor. Some tech guy told me on the phone. That As along as I dont change the Cubic Inch of the motor. IT will NOt fall flat on its fast. My only concern is the Computer reading The new cam. So my quiestions is this. Of course I need to get my CAR tunned. I Have no Cash for tha tright now. DOes my car need to be flashed. OR will the STOCK OBd1 computer READ the new CAM that I have installed. its a COmp Cam Ex 224/230 .503/.521?? Thanks please Reply. I also have a Hypertech Proggramer as well
THanks
CHris
Old Jul 8, 2003 | 02:52 PM
Andrew Duke's Avatar
Your car will run fine with the new cam if everything is set up right, however, until you get it programmed it won't run at it's full potential. When i changed my cam I ran a w/o programming. With pcmforless i ran a 12.9. The programming was set up to pull some timing because i was spraying so I could have more power n/a if I had advanced the timing... so basically if I were you the next 150 bucs i had would go to programming.
Old Jul 8, 2003 | 02:59 PM
LT1CST's Avatar
Andrew thanks dude
another questions. I have a Hypertech Programer as well. WOuld I get any Benifits from the Programmer with my new CAM?? Also It sounds like what you said. ALL i wont to do is get the damn computer reprogramed to read my new Cam right? wondering Y alotof these dyno places are telling me 650 bucks to start. IM like man. all I want is to get the car running. Ill deal with the rest later lol
Chris
ttt
Old Jul 8, 2003 | 03:02 PM
LT1CST's Avatar
OH and another things. HOW MUCH will a Hypertech Programmer READ. How much can it take?
CHris
ttt
Old Jul 8, 2003 | 03:13 PM
T/A KID's Avatar
Hey LT1CST I have a OBD1 PCM that I can't use anymore (I use a different PCM now) This PCM is tuned BY PCM for less. I can sell you this PCM and for like $20 bucks you can send it to Bryan at PCM for less to RETUNE THE PCM for your cam and other MODs.
The reason you wont get charged for the regular $275 pricing is because this PCM has already been done and you can get it reprogrammed for your car.
You can probably can around 15-20RWHP out of just the PCM since you have a cam.
Here check out the website.
http://www.geocities.com/pcmforless/index.html
Let me know if you want to buy my PCM and I will sell it to you cheap. Thanks T/A KID
Old Jul 8, 2003 | 03:17 PM
ONELOUDKAR's Avatar
I had the Hypertech and it completely sucked. Might be good for a stock car though but other than that.... having a cam with a cam in it needs to be tuned right I would think. Call Bryan at pcmforless and get things going with him and you will be set. Will those springs and rockers hold up with that size cam?
good luck
-Mike
Old Jul 8, 2003 | 03:28 PM
TedH's Avatar
At one time, years back, I had a Hypertech unit for my '94. When I got my heds and cam it was less expensive to buy the Hypertech heads and Cam module for it. That was a big mistake. The car slowed down dignificantly with their programming.
I removed the Hypertech stuff and got a mail order tune which was much better. The best way is to get a dyno tune from someone who knows how to program, but most of the established mail order tuners will offer a decent improvement over stock tuning.
Old Jul 9, 2003 | 12:40 AM
94 TA TT2S's Avatar
I'm with TNTHUB......I had the exactsame setup with the hypertech programmer and chip.....I went with Brians tune...Much better feel.....Better idle ......Brian is well worth it compared to the hypertech from my experience
IgorT.455/406
Mar 12, 2015 03:39 AM
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
cmdeshon
Dec 27, 2014 10:06 AM
