OBD-I to OBD-II?
Old Feb 14, 2005 | 02:05 PM
96camarors's Avatar
OBD-I to OBD-II?
Searched but couldn't find anything really.
I've got an early 95 LT1 in my 96 RS. But in order to get it smogged here in California it has to be OBD-II.
If I get a 96 LT1 computer and knock sensor, is that all I'll need? I'll only need it to run for about a mile to the smog test place and back
The computer I've got in there is working perfectly fine, but it's an OBD-I.
Thanks in advance
Old Feb 14, 2005 | 02:12 PM
sssalah's Avatar
Re: OBD-I to OBD-II?
OBDII cars come with a crank position sensor for misfire detection, and also post cats oxygen sensors.
Old Feb 14, 2005 | 02:15 PM
96camarors's Avatar
So it's not easy then
Old Feb 14, 2005 | 02:31 PM
Hawk's Avatar
here's what I would do. Get the OBDI II and hook it up, and get it programmed to eliminate all codes that will be thrown(eg post cat 02's, knock sensor, etc). You could even program out that misfire detection. THis is something maybe you could contact one of the tuners about, maybe madwolf can help?
Brian
Old Feb 14, 2005 | 05:11 PM
madwolf's Avatar
Is it just smog that you need to pass or also the scan test?
Old Feb 14, 2005 | 05:45 PM
Rob(94Hawk#319)'s Avatar
Unfortunately, scan test too.. I dunno if deleting the CPS and extra knock sensor, o2's, etc.. would pass the ready/not ready test. Ion, can that be done?
Old Feb 14, 2005 | 05:55 PM
turbo_Z's Avatar
I have heard turning off the DTCs will not actually pass the scan test but I cant varify this.
Novo
Jun 14, 2016 02:58 AM
Aug 7, 2015 08:52 AM
cmdeshon
Jan 4, 2015 11:15 AM
ZPaul2Fresh8
10
Jun 18, 2004 01:15 PM
Camaro_Maniac63
May 24, 2003 03:39 PM
