Obd-1 Obd-2
Old Oct 22, 2003 | 02:56 PM
airborneluva's Avatar
Question Obd-1 Obd-2
what does this mean, what's the difference , thanks
Old Oct 22, 2003 | 02:59 PM
FacelessZ's Avatar
OBD 1 PCM's came in 95 and earlier LT1's...OBD 2 PCM's came in 96 and later LT1's and LS1's...
They are the main "brain" of the car...
jonaddis84's Avatar
OBD1 is the computer used in 93-95 cars. OBD2 is in 96 up cars. Basically the only difference from what I know is a different knock sensor, and some programming differences I think.
Old Oct 22, 2003 | 03:02 PM
ibanez6rg's Avatar
On-Board Diagnostics
OBDI is older = 93-95
OBDII is newer = 96-
OBDI > OBDII
Old Oct 22, 2003 | 03:05 PM
FacelessZ's Avatar
One cool thing about the OBD 2 is that you can program your fans to run an extra couple of minutes even after your car is shut off in order to cool your engine...
Aside from that the OBD 1 is preferred...only you may run into problems when you get a 3200+ stall converter...
Old Oct 22, 2003 | 03:09 PM
DarkRider's Avatar
I too have the same question
What kind of scanners or diagnostic tools can you hook up to OBD1 to get trouble codes?
TransAm219
Jun 16, 2004 11:04 AM
lt1ownsall
Apr 30, 2004 10:22 PM
ram air camaro
Dec 15, 2003 08:52 PM
94 TA TT2S
Oct 4, 2003 07:14 PM
