o2 sim ?
Old Mar 22, 2006 | 07:48 PM
steves97z28's Avatar
o2 sim ?
For a few months now i have been having problems with my passenger side o2 sim. It went bad and i replaced it again only to have it go bad again. I thought the problem may be the harness coming from the motor. So at this point i switched my sim from the drivers side to the passenger side. Now the code has followed sim, so its not in the harness. The o2 sim on the passenger side is pretty close to the header, is it possible the heat is killing them? I think that may be the problem. If that is the problem what can i do to protect them from the heat
Old Mar 22, 2006 | 10:42 PM
Re: o2 sim ?
Old Mar 22, 2006 | 11:24 PM
Re: o2 sim ?
Why do you have to keep the sims located right next to the hot exhaust? Why not move them away from the heat altogether?
Old Mar 23, 2006 | 12:01 AM
Re: o2 sim ?
I have tried to move them but the seem stuck, ill have to make sure they are not wired tied up or anything(I didnt install them). but thats the only thing i can think of that would cause them to consistantly go bad on that side
Old Mar 23, 2006 | 01:45 AM
Zeueses 97 RamAir's Avatar
Re: o2 sim ?
Heat kills o2s wrap them up or do something get a temp raeding on them before and after see if that helps them ...
Old Mar 23, 2006 | 05:12 PM
Re: o2 sim ?
what should i wrap them in?
Old Mar 23, 2006 | 05:26 PM
2000GTP's Avatar
Re: o2 sim ?
I just secured my sim. away from the header with some zip ties, it hasn't caused any problems.
Old Mar 23, 2006 | 06:38 PM
Re: o2 sim ?
Ya im gonna try to move it, but want to wrap it to, because i dont feel like spending another 50 bucks for another sim
Old Mar 23, 2006 | 10:31 PM
Re: o2 sim ?
get some plug loom heat wrap and use 2 on each one cut with razorblade.
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
WS6T3RROR
Apr 15, 2003 02:01 PM
lbrowne
Apr 9, 2003 11:56 PM
hotrod18_69
Feb 11, 2003 03:29 PM
