O2 Sensors
Old Jun 18, 2009 | 05:02 PM
revolution79z28's Avatar
O2 Sensors
Alright, maybe I can get someone to explain to me exactly how these things work. I have a '93 Z28 and I did a longtube header install about a year ago and I replaced the O2 sensors with Bousch brand. My car has a stumble from 1200 rpms to 2500 rpms. I unplugged both sensors yesterday and I have no SES light and my car takes off like a rocket. Why is this? Why would the O2 sensors cause a stumble when plugged in and run fine unplugged? Does it hurt anything to run it like this? Do I need to try a different brand? I'm confused. Thanks for any help.
Old Jun 18, 2009 | 05:12 PM
JooneJune's Avatar
Just put bolts in the O2 sensor bungs and Tune them out. You don't needum... =) I don't have um. I got my bolts on eBay, i forget the size and specs...
Old Jun 18, 2009 | 09:40 PM
MikeGyver's Avatar
You most likely have a vacuum leak or something else is out of whack so the 02 sensors cannot adjust to the desired air fuel ratio.
Old Jun 18, 2009 | 11:12 PM
There are numerous engine problems that can cause the O2 sensors to cause the engine to run poorly. The solution is not to get rid of the O2 sensors. The solution is to find out what is causing the problem. Misfires, exhaust leaks before the O2 sensors, and faulty sensors and wiring can all cause the O2 sensors to read incorrectly ("false" lean or "false" rich), forcing the ECM to add or subtract fuel that should be added or subtracted.
When they work correctly, they help compensate for minor changes in the way the engine runs... variations in fuel pressure, minor vacuum leaks, or aging IAT and MAP sensors on your 93 speed-density ECM.
browenb
May 30, 2022 05:45 PM
shock6906
Feb 1, 2008 09:31 PM
HaynesFaithZ28
Feb 3, 2005 08:59 AM
Red96Lt1
Aug 13, 2003 04:02 PM
MarkyMark
Mar 30, 2003 12:55 PM
