O2 sensor question for those of us using narrow band
Old Aug 27, 2005 | 11:47 AM
93z383's Avatar
For us who still have non heated and narrow band one wire o2 sensors, is there a way to convert to wb? or is it even an option or a good idea?
Old Aug 27, 2005 | 11:56 AM
ltwonz's Avatar
Re: O2 sensor question for those of us using narrow band
Check out thislink. It's from a site just for us 93's.
http://www.speeddensity.org/showthread.php?t=287
Old Aug 27, 2005 | 12:43 PM
93z383's Avatar
Perfecto, did you do this mod and did you notice improvment.
Old Aug 27, 2005 | 02:52 PM
ltwonz's Avatar
I have not done this yet because i haven't had any problems with the single wire style.
Old Oct 7, 2005 | 04:30 PM
Demus's Avatar
A lot of the controllers that come with wideband O2 kits will produce simulated narrowband O2 output.
Old Oct 7, 2005 | 10:06 PM
96capricemgr's Avatar
Just to make this clear, the 94+ cars still use a narrowband it is just heated, to use a wideband with a stock pcm you would need something like what Demus mentioned as far as a controller that will send the signal.
DirtyDaveW
Mar 15, 2015 07:01 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Z28 97'
Aug 4, 2002 09:43 AM
