O2 sensor question
Old Dec 17, 2006 | 11:26 PM
LT1_King's Avatar
O2 sensor question
how many O2 sensors would i need to buy for a 94 Z with one cat OBD1? and are they hard to replace?
Old Dec 17, 2006 | 11:55 PM
bingo's Avatar
Two O2s. They are not too bad. I think I removed one with a wrench and one with an O2 socket. I have only done this once on a 4th gen and it was last year. If they are original they might put up a fight.
Old Dec 18, 2006 | 09:56 AM
OBE1 95Z28's Avatar
Do yourself a favor and use AC Delco O2 sensors; people have had issues with other brands.
Old Dec 18, 2006 | 10:00 AM
69gto96z's Avatar
I used Bosch and am about to buy me a set of AC's.
Old Dec 18, 2006 | 10:31 AM
EnerjetF67's Avatar
I have Denso 02's and will not use anything else.
They are extremely tolerant of using leaded AV100 or Torco 110 fuels.
Old Dec 18, 2006 | 11:47 AM
2000GTP's Avatar
One of the 02 sensors gave me a pretty good fight, I had to soak it real good with PB Blaster and also had to heat it up with a torch before it finally broke loose. Removing the other one was quite painless.
Old Dec 18, 2006 | 02:11 PM
LT1_King's Avatar
do i need a lift to do this or is it possible to do it on jack stands? and what size of wrench and or socket would i need to do the job?
Old Dec 18, 2006 | 03:57 PM
2000GTP's Avatar
I'm pretty sure its a 7/8" socket/wrench size, I can't remember completely off the top of my head though. But yes, you can do this job on jackstands.
Old Dec 18, 2006 | 10:44 PM
LT1_King's Avatar
at the local auto stores they don't carry AC Delco they just carry the bosch and the denso. what would be better for the car? see i'm gonna do LT's in about a couple of months but for now which ones would i need to go with? and just about how long did it take you guys to do this?
Old Dec 19, 2006 | 12:59 AM
Craddock's Avatar
I have bosch and they suck, I might have just gotten a bad sensor, but the sensor I bought went bad within days. If you can't get AC Delco go denso.
Old Dec 19, 2006 | 06:09 AM
Dave89IROC's Avatar
IIRC, the Ac Delco ones are made by Denso, so you are good
Old Dec 19, 2006 | 11:13 AM
2000GTP's Avatar
Personally, I haven't had any trouble with the Bosch sensors, but with the problems that many others seem to have, it would be safe to stick with the Delcos. You can get them pretty cheap from one of these guys:http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
The only reason I bought the Bosch's was because I didn't want to wait for them to be mailed because I was trying to get my car together quickly for its emissions test.
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
