O2 sensor milivolts...
Old Mar 11, 2008 | 06:03 PM
LSWHO's Avatar
how much should they be when operating correctly?
The one on the passenger side is 455ish.
The driver side (which is throwing codes) varies from 150ish to 500ish.
Is this any indicator as to what is actually wrong? Does this show that it probably ISN'T a wiring issue? Or does this tell me nothing at all?
Thanks,
Scott
Old Mar 11, 2008 | 08:10 PM
greenmachinedriver's Avatar
they shoud swithc between rich and lean. 0.0v to 1.0v low voltage is lean high voltage is rich. what codes are you getting?
Old Mar 11, 2008 | 09:13 PM
mrmint69's Avatar
They should change between 100's and 900's several times a second. If the car wasn't in closed loop this could cause them to look this way. After the car warms up enough they change rapidly and usually go with one high number and then a low one and so on. A bad sensor will usually do what your saying but if the wiring is burnt or damaged this could also make them read wrong.
Old Mar 11, 2008 | 09:21 PM
94_PatriotRed_Z's Avatar
Switch the sensors from side to side and let the car warm up, then check the readings. If the code changes from driver side to passenger side then you know you have a bad sensor, but if the code stays on the driver side then you know you have a bad wire somewhere
Old Mar 11, 2008 | 09:32 PM
brubaker's Avatar
To be more helpfull we will need code numbers and code description, a failed 02 heater will set a code and turn on the ses light! remember your car is obdII in closed loop you fronts should switch your rears shouldn't unless it has no cats or failed cats.
Old Mar 11, 2008 | 09:54 PM
LSWHO's Avatar
These are idle readings. the driver side changed every time I turned the car on, and i did it a LOT. The passenger side read the same the whole time.
The code is low circuit voltage and another I don't remember.
Old Mar 11, 2008 | 10:51 PM
mrmint69's Avatar
You have to run the car until you get it into closed loop before you can get any kind of accutate reading of the sensors. If you turn the car off it will make the car go to open loop until you meet the cryteria you need to get it in closed loop again. Until the sensors reach 600 degree i think they will not work correctly.
Old Mar 12, 2008 | 01:20 PM
If the sensor stays near 450mV, even in open loop, either the wire/circuit is "open", or the sensor is deceased. What you are seeing on your passnger side is the PCM's own bias voltage, indicating the sensor is not working.
Even in open loop, as the sensor starts to warm up, it will start to drift toward lean (AIR pump operating) or toward rich (AIR pump deleted) slowly, over the two minutes or so that the PCM allows for the sensors to reach the required operating temperature.
Old Mar 12, 2008 | 03:30 PM
LSWHO's Avatar
Bank 2 sensor 1 is the passenger side front?
Old Mar 12, 2008 | 03:35 PM
Yes
Old Mar 12, 2008 | 03:37 PM
LSWHO's Avatar
Oh duh. I got it now. I didn't even think about this before posting.
Old Mar 12, 2008 | 09:33 PM
Oxygen454's Avatar
Hope that works for you. I work with a mechanic and he said that sometimes the voltage readings on a voltmeter show the correct voltages but the wave lengths may be incorrect. (sort of like a frequency reading) In this case you need a scope to scope it out. Hope this is not the case for you... just my 2 cents.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
