Eagle Rod Clearance question
Old Mar 10, 2008 | 04:17 PM
cvccbum's Avatar
Hey all -- I've searched but didn't find a ton of info on this question.
I have these pistons:
http://store.summitracing.com/partde...4&autoview=sku
And I'm looking to get these rods:
http://store.summitracing.com/partde...D&autoview=sku
My question for you all is will I have alot of clearance problems with these rods? It's going to be a 355, forged GM crank.
I've heard alot of bad things about these rods in that department, so I thought i'd check before I went ahead and bought them.
If those are going to be too much trouble I was thinking of getting these:
http://cgi.ebay.com/ebaymotors/New-S...spagenameZWDVW
Any opinions are welcome, I need all the advice I can get. Thanks!
Old Mar 10, 2008 | 05:23 PM
FASTFATBOY's Avatar
Stock stroke crank, no problems.
David
Old Mar 10, 2008 | 05:27 PM
cvccbum's Avatar
Awesome. Thanks for the quick response!
Old Mar 10, 2008 | 10:26 PM
Cook Performance's Avatar
You will have no problems with the eagle rods. Even in stroker applications they work great when the block is clearanced properly. Some people claim they have busted through to coolant on strokers with these rods. I have built many engines with these rods. No problems at all. Depending on your application, I would recommend upgrading to ARP 2000 rod bolts.
Cook Performance Engines
Old Mar 10, 2008 | 11:41 PM
SS RRR's Avatar
One of the complaints with these rods is the rod bolts are at a length to where proper clearencing is touch and go. Do the 2000 rod bolts have a shorter profile?
The shop that built my 396 broke into a water jacket and recommended CompStars. The block was replaced and they had no problems w/ clearencing. These and the Eagles (6") were put up side by said and there is about a .100 difference between the two rod bolt profiles w/ the ComStars being shorter of the two.
Old Mar 11, 2008 | 01:53 AM
Dave1980's Avatar
Yeah that was one of the things that made the compstar rod more attractive to me for my build.
Old Mar 11, 2008 | 07:30 AM
FASTFATBOY's Avatar
Hes building a 355
David
Old Mar 11, 2008 | 03:14 PM
SS RRR's Avatar
Originally Posted by FASTFATBOY
Hes building a 355
David
Please read my question to proflowjake.
Old Mar 11, 2008 | 06:48 PM
The ARP 2000 rod bolts do not have a lower profile. They require the same amount of clearance work as a 8740 or L-19. I pressure check every block after any clearance work is done to show if a cut is made to deep and into a coolant passage. I do agree that compstars are of a lower profile and they do require less clearance work. However, Buck for buck, Eagle is cheaper to build, therefore prices can be dropped without sacrificing engine reliability.A Compstar crank and rods can be upgraded for about $600-$700. But like I said, I have never had a problem with Eagle. It takes careful precise cuts with attention to detail. Doing clearancing work with H-Beams and a stroker takes alot more time than I beams and a stroker. Either a 383 or 396.
This is my opinion about these parts. Other may agree or disagree.
Old Mar 11, 2008 | 07:23 PM
SS RRR's Avatar
Appreciate the input.
Old Mar 11, 2008 | 08:50 PM
klrz28's Avatar
I was told 6'' h beams wont fit with a standard base circle cam. Is that true? with a 3.75 stroke?
Old Mar 11, 2008 | 08:52 PM
tireburnin's Avatar
My L-19 rod bolts required clearencing. I have a 3.48 stroke crank (355).
I have pictures on my old comp, but some of the bolts required a good bit of clearencing to the block.
Old Mar 11, 2008 | 10:02 PM
6" h-beams WILL clear a standard base circle cam in a stroker application. I beams will not clear a standard base circle cam without clearance work on the rods. Eagle now provides this service free of charge to all of there I beam rods so they will clear a standard base cams.
Old Mar 11, 2008 | 11:01 PM
SS RRR's Avatar
I too have a friend who had to clearence a 355 block on a ZZ4 engine of his.
Old Mar 12, 2008 | 12:22 AM
marshall93z's Avatar
What?! I just installed Eagle I-beams with no camshaft interference...maybe my cam wasn't "standard base circle".
