o2 sensor locations
o2 sensor locations
Where are they all located on a 96 Z28
i did an OBDI swap and i get a code from the passenger side o2 sensor...
Is it the square plug or the more rectangle plug that i must plug that one into?
b/c i do have it plugged into the square one..
Thanks!
-Oliver
Thanks!
-Oliver
Originally posted by shoebox
The sensors with the square connector are the post cat O2s. Since you did an OBD-I swap, they are completely ignored. Only the pre cat ones with the flat connectors are used with OBD-I.
i cant seem to find em!?
Thanks again!
Oliver
carguyshu
Jan 22, 2017 11:19 AM
