o2 sensor locations
Old Mar 21, 2003 | 07:32 AM
ollie-99's Avatar
o2 sensor locations
Where are they all located on a 96 Z28
i did an OBDI swap and i get a code from the passenger side o2 sensor...
Is it the square plug or the more rectangle plug that i must plug that one into?
b/c i do have it plugged into the square one..
Thanks!
-Oliver
Old Mar 21, 2003 | 10:23 AM
You need to connect the PCM to the pre-cat sensor. That will be higher up on the Y-pipe branch, before the cat. Do not connect anything to the sensor after the cat.
Old Mar 21, 2003 | 10:34 AM
ollie-99's Avatar
yeah i connected that one right into the header from the o2 sensor right near the middle spark plugs on that side
Old Mar 24, 2003 | 01:06 AM
ollie-99's Avatar
ttt
Old Mar 24, 2003 | 08:20 AM
The sensors with the square connector are the post cat O2s. Since you did an OBD-I swap, they are completely ignored. Only the pre cat ones with the flat connectors are used with OBD-I.
Old Mar 24, 2003 | 10:33 AM
ollie-99's Avatar
any idea where they are located on the passenger side?
i cant seem to find em!?
Thanks again!
Oliver
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
Jazsun
Dec 29, 2014 12:14 PM
bsmith
Jul 19, 2002 06:08 PM
jgkinsofla
Jul 18, 2002 11:06 AM
