o2 sensor issue...
Old Aug 24, 2006 | 04:18 PM
terrible 1's Avatar
o2 sensor issue...
for some reason i just went thru 2 brand new bosch o2 sensors within 2 weeks. what the heck could cause this?
Old Aug 24, 2006 | 04:32 PM
2000GTP's Avatar
Re: o2 sensor issue...
Is it the same sensor on the same bank, or did the sensors on both sides fail? Did you just do a header install? If so, the coating on the headers tends to kill 02 sensors during initial startup. Also, another thought, the Bosch sensors have a hit or miss reputation on here. Alot of people have had trouble with them and have had better luck just using the Delco replacements.
Old Aug 24, 2006 | 05:42 PM
How do you know the O2 sensors failed? What were the symptoms?
Old Aug 27, 2006 | 01:04 PM
terrible 1's Avatar
well it would run fine on a cold start then start idling really bad and burn rich. then the SES light poped on and it ran great. i figured it was the o2s but i wasnt sure cause i replaced both about and it ran alright for a day i belive. so i took it to a shop and they scaned it and he said the passenger side was sticking. that explains why the SES light would go on and off. i did the headers about a year and havnt had a problem till now. i guess ill try the oem replacements
Old Aug 27, 2006 | 02:30 PM
terrible 1's Avatar
wait...are there any after market o2's with long enough wires for the LT's?
Old Aug 27, 2006 | 02:36 PM
gixxer92's Avatar
No FLP, speed Inc, thunder and many others offer extensions for the o2's, did you happen to put new Header gaskets on and use RTV around the gaskets? I know RTV can sometimes cause o2's to fail with the curing compund attaching to the element in the o2.
Old Aug 29, 2006 | 03:06 PM
terrible 1's Avatar
nope i just used the felpro header gaskets. it was great for about a year.
Old Aug 29, 2006 | 03:09 PM
2000GTP's Avatar
Do you have the locking header bolts? If not, are the standard bolts snugged down?
Old Aug 29, 2006 | 03:26 PM
CamaroSS30thAnn's Avatar
if its not a header leak id have to say try ac delco or some other brand of 02s
bosch are not my first choice for anything
Old Aug 29, 2006 | 07:38 PM
96torqueman's Avatar
O2 Simulators www.jegs.com
Old Aug 30, 2006 | 05:52 AM
terrible 1's Avatar
what about ngk? those are at summit.
Old Aug 30, 2006 | 07:34 AM
For what? You can't use "O2 simulators" in the pre-cat position, and his 94 only has pre-cat sensors.
terrible 1:
Get the EXACT code that is turning on the SES light. There are several for the O2 sensors, and even though the code description includes the O2 sensors, it does not necessarily mean its the O2 sensor that is causing the problem. The problem may be somewhere else, and affecting the A/F ratio to the extent it sets the O2 sensor code(s). Replacing them without getting the code first was a mistake.
Old Aug 30, 2006 | 01:07 PM
terrible 1's Avatar
they guy at tuffys said the passenger side o2 was sticking. i replaced it and it was good for about a week. ps. i was talking about the ngk o2 sensors.
Old Aug 30, 2006 | 06:32 PM
There is no code for an O2 sensor "sticking".
Old Sep 1, 2006 | 10:49 PM
terrible 1's Avatar
that is all i kno about the scan
