O2 sensor or connector
Old Feb 14, 2008 | 04:13 PM
350pride's Avatar
My car throws a code about a mile after I hit 60 mph. Not crusing around town, only after I hit 60. So I scanned the car, and it said left side 02 sensor or connector. So does this mean I just need to buy a new O2 sensor?
thanks,
pride
Old Feb 14, 2008 | 04:30 PM
2000GTP's Avatar
What code did you get specifically? It might not be your sensor or connector per say.
Old Feb 14, 2008 | 04:53 PM
ss.slp.ls1's Avatar
I would check the wires and connector for damage or corrosion. If it looks ok, they you probably need a new o2 sensor. Get specific code, your front o2 sensors affect your air/fuel ratios, your rear ones only keep track of your catalytic converter efficiency.
Old Feb 14, 2008 | 04:57 PM
350pride's Avatar
i dont have any sensor behind the cat...94 model....also I dont know the specific code bc I had it scannd by someone. they scanned it with snap on scanner... and it said left sensor or connector.
thanks,
pride
Old Feb 14, 2008 | 05:15 PM
2000GTP's Avatar
You could always swap sensors from bank to bank. If the trouble code follows, then you know you have a bad sensor.
Old Feb 14, 2008 | 06:42 PM
ss.slp.ls1's Avatar
thanks,
pride
Sorry, I gotta read sigs.
Old Feb 15, 2008 | 09:39 AM
Why not just give us the EXACT code, so we can help?
Old Feb 15, 2008 | 03:40 PM
Big Lebowski's Avatar
Ya, Need exact code to help. the scanner says bank 1 or 2 not left or right. You could start by looking at the wires and connectors. They could be corroded or melted. Other than that we need the code.
Old Feb 15, 2008 | 05:11 PM
Its not just an issue of left or right... its an issue of there being more than one set of DTC's for the O2 sensors. One set for sensor open circuit, one set for sensor lean and one set for sensor rich. The code can be the result of something being wrong, other than the sensor itself, or the wiring. Knowing the exact code makes it easier to make suggestions as to the possible cause.
Richardan15
May 30, 2015 08:36 AM
94Z28LS1toLT1
May 27, 2015 10:44 PM
squarehead
Jan 15, 2015 07:02 PM
