O2 sensor bad?
Old Jul 28, 2010 | 08:12 PM
91TPI's Avatar
O2 sensor bad?
94 Z28, 113K miles, LT1 - auto, K&N CAI, Hooker long tubes, PI converter (2800), 3.73 gears, newer opti-spark - waterpump, newer plugs & wires, newer ICM.
I have a slight hesitation/miss that seems to come around after warmup and the car is in closed loop. It is only noticable under light to moderate load. WOT I don't seem to notice anything (other than some black smoke). It is running rich as evidenced by the smoke and carbon build up on the tailpipes. I only got 13mpg last tank of gas and that was highway mostly! Some readings from the scanmaster are as follows: LIN/RIN = 120-130/180-190, LBL/RBL = 120ish/160ish, LO2/RO2 = 449/normal up and down movement. This was all read at cruising speeds of 70mph. It seems the LO2 wants to "stick" at 449 but will jump around periodically. I am not sure how old the O2 sensors are, they were on there along with the longtubes, when I bought the car at 98,000 miles. So my question is whether or not the O2's are shot? Any help from the knowledgable people on this board would be much appreciated!
Old Jul 29, 2010 | 06:34 AM
MikeGyver's Avatar
If your sensors are staying at ~.45v then they aren't connected, warmed up, or are dead. If a sensor isn't cycling (or stops cycling), the PCM will revert to open loop control as the perceived o2 status is "not ready". If the sensors are cycling within a couple minutes of cold startup, then they are usually fine.
I wonder if the 'sticking' is simply due to a slow sample rate (or averaging) of the scanmaster.
Old Jul 29, 2010 | 06:45 AM
bw_hunter's Avatar
I assume you don't have a SES light...correct?
Since headers are involved, look for an upstream exhaust leak..that will make it run rich.
I've seen weird responses from non-GM O2 sensors after they age so it might well be the sensors since you don't know the age or brand. To be clear, the wierd responses I've seen weren't on an LT1...it was an LS6 with NTK (NGK) sensors. They are a 'wear' item like plugs, wires, and distributor caps and have a finite life...
Old Jul 29, 2010 | 08:55 AM
91TPI's Avatar
Yeah its kind of odd because the reading will hang out at 449, then bounce around for a bit, then back at 449. This is only on the left O2, the right one never sticks at any number once in closed loop... acts normal.
Long story short, I bought this car back from the guy I sold it to about 7 years ago.... he never drove it and I found that one header bolt was gone and one was about to fall out, both on drivers side. I've gotten that squared away. Now I am in the process of cleaning the motor out (seafoam) to try and get rid of any carbon build up. I just want to make sure I am not going to throw $140 away on new O2's!
Old Jul 29, 2010 | 12:48 PM
Sounds like there's more to it than that.
The driver's side (left) O2 circuit probably has an intermittent connection. Reads ~450mV when its disconnected, than starts to function normally when the connection is temporarily re-established. The loose bolts on the driver's side manifold should have caused elevated long term fuel corrections (BLM's), but if they are "120ish" they aren't elevated.
Then there's the passenger side (right). With a 160 BLM, its adding 25% extra fuel. The 180-190 INT is adding 45% extra fuel. Since the terms are multiplied by each other, its adding 80% more fuel than the PCM thinks it should add. You really need to figure out if that is a "true" lean condition that is being corrected, or a "false" lean condition. If its a false lean, the oil is probably full of gasoline by now. The plugs should be totally carboned up .
So far, I don't think you've figured it out at all.
Old Jul 29, 2010 | 10:07 PM
91TPI's Avatar
Thanks for your help. I need to correct myself, it was the passenger side header with the loose/gone bolts. Also there are no codes being set.
The RBL seemed to stay at 160 today while the LBL was at 120. The RIN was reading around 140-150 and LIN 120-130.
The oil was fairly fresh according to the previous owner but when I checked it, it looked pretty black (used up). The extra fuel being dumped in (if that is the case) could have caused this, correct? I did pull the cylinder 1 plug and it didn't look bad. I guess I need to pull a few plugs on the pass side.... The car only got about 8,000 miles put on it over 7 years so I don't think all the sitting around did it any good!
Old Aug 2, 2010 | 09:19 AM
91TPI's Avatar
Update: Looks like I was on the right track.... I think the rich condition started out as a header exhaust leak and kinda snowballed from there. Everything I saw pointed to bad 02 sensors (the right one was completely clogged with carbon build-up) so i installed new acdelco ones and problem fixed! Thanks for your help/info guys!
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
