o2 problem? running bad in closed loop
Old Dec 29, 2006 | 09:38 AM
plan Z's Avatar
ok i just replaced my o2's about 6 months ago. all of the sudden my car is running bad as soon as it hits closed loop. i figured it wasnt the plugs/wires/fuel pump or filter because of the fact that the car runs fine in open loop. i even changed my tune back to make sure it wasnt that. im not throwing any codes. my o2 mV readings look like this. the driversside fluctuates between 50-850 at idle or low/normal driving. the right side is between 150-1000. my lterms on the driversside are a little above 128 (green/rich?) and the passengerside are a little below 128 (red/lean?). its hard for me to tell if this is any different from normal because of my cam i have had split blm's anyway. so am i right to think that i have a problem with one of my o2's? if there was an issue with one of the wires (whether it was open or shorted) wouldnt it throw an o2 code?
HCz28
Jan 11, 2015 11:21 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
slothgrant
Aug 22, 2002 03:01 PM
