O2/Knock Sensor Pigtails??
Old Feb 5, 2005 | 04:19 PM
pennys58's Avatar
Was wondering if someone knew if there are pigtails for the O2 sensor and Knock sensor. Somehow, through routing the wires, the heat shield burnt through and the wires ended up melting causing a short...causing the fuse for the fans/o2 sensor to blow. They go to the pasanger side and pasanger header. The knock wire has a male end and the o2 looks like a female end. Anyword of something out there?? Thanks for the help.
John
Old Feb 5, 2005 | 04:55 PM
Re: O2/Knock Sensor Pigtails??
Pig tail part numbers
The pig tails listed for the O2s are for the wiring harness side. If you burnt up the O2 side, you will have to get a new sensor as the connector is part of it.
Old Feb 5, 2005 | 06:26 PM
pennys58's Avatar
On the O2 sensor, the part that is burnt, is the one that goes down to the o2 extension...so I guess I should get the 94-97 front o2 sensor tail??...I REALLY apreciate your help...I couldn't find that "pig-tail" list on your site, originally...I think of your site as the one stop shop...Thanks again!!!
edit:I see where it was...looking for pig tails...
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
gelbza
Jul 12, 2015 08:10 AM
