o2 extension length
Old Jun 19, 2003 | 06:45 PM
got_hp?'s Avatar
o2 extension length
tried a search, but couldnt find an answer
what length O2 extensions are people using for jethot lt's?
Old Jun 19, 2003 | 07:18 PM
got_hp?'s Avatar
ttt
Old Jun 19, 2003 | 07:32 PM
anaik's Avatar
I used a 24" extension on my FLP's. Probably the same for the Jethots.
Old Jun 20, 2003 | 08:20 AM
revtime's Avatar
Yep, I extended mine 2 feet.
I could have went a little shorter on the passenger side but I relocated the O2 wire away from header heat.
I have Hooker JH LTs by the way.
Old Jun 20, 2003 | 11:14 AM
kmook's Avatar
Advanced Tech Moderator
I got mine from ThunderRacing. I dont remember if they were 18 or 24", but nonetheless they were longer than i needed (which is good).
Old Apr 20, 2004 | 12:43 AM
Dave88LX's Avatar
Do both sides require 24" I assume to get them to reach for Jet Hot LT's?
Ion said that I only use the front O2's and not the rear correct?
Guess I would need this here (2 of em):
99-O2EXT Oxygen Sensor Extension, 24" Flat 4-Pin (Front Sensor on 1994-1997 F-body, Front & Rear on 1994-1996 Impala SS) $25.00
13qtr
Oct 28, 2016 08:11 PM
FredM
Exhaust System
Feb 8, 2016 02:10 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
