o2 code and misfiring.. PLEASE HELP!
Old Jul 10, 2004 | 01:23 PM
  #16
roadrage912's Avatar
Originally posted by med_reject
roadrage, fuel pressure should be around 43 psi. It should not go down after 10mins. Is this what you are reading after fixing the fuel pressure regulator?
like i said before the fuel presure is fine. we've just gotten behind on this post maybe. we've changed spark plugs, wires look good, regulator is a few hours old. all the other things like opti, icm, and coil have maybe 2000 miles on them. we're trying to get it scanned but the guy doesn't show up when he says he will.
Old Jul 10, 2004 | 02:50 PM
  #17
KillinFormula's Avatar
we have also ruled out injectors leaking
Old Jul 10, 2004 | 03:51 PM
  #18
med_reject's Avatar
is the problem there all the time or only in closed loop (when the engine warms up)?
Old Jul 10, 2004 | 05:38 PM
  #19
only in closed loop
Old Jul 10, 2004 | 08:44 PM
  #20
ok, changed out the other 02 and so far no misses or code. stupid lying SES lights. the code was for bank 2 but bank 1 was running rich by the plugs and 02. we spent quite a few hours on the scanner today and the misses followed the bad 02 and we did a lot of stuff. hopefully it's all finished with.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
