o2 censer
o2 censer
i had a code coming up and it was the o2 censer reading wrong so i went in and fixed the wiring so it would read right and keep the same censer in it just replaced. but ever since i did that its been running way different i will just cruse at 2 grand then if i go to push on the gas harder it bogs out then takes off after a few sec jw what you guys think it might be it is a lt4 set up with tune
Re: o2 censer
Your o2 SENSOR might need changed, although it is hard to determine what exactly you did to try and fix it.
At full throttle your car doesn't use the o2 sensors for how much fuel to use, just the PE tables in the tune. Therefore if it is running crappy when cruising likely there is an issue with either the wiring, or the sensor itself, or possibly both.
Add a signature that has basic car info to help with responses as well.
Re: o2 censer
since it is obd 1 i went a my buddy shop and he hooked it up and it was not a code number it said it on the screen and we went into shopkey to find what were the right color cords go with one another no check engine light now just running like crap took the plugs out today and were like new burning perfect the best way i can ex plane the way its running is if you ever felt you car over heat it feels like. it loose tons of power then out of no were after a few sec it takes off
Re: o2 censer
http://shbox.com/1/Dtcs.htm
The code tells you which bank of the engine the code is for. It tells you whether the code is for the O2 sensing element, or the electric heating element/circuit in/to the sensor. It tells you that the code may be the result of something other than the sensor itself. Could be the result of running lean, running rich, etc.
I'd like to help, but the description you give is impossible to decipher with no punctuation, incorrect spelling, etc.
Re: o2 censer
In the original post you said you had a code, and in the second post you say that it didn't? I don't typically help much, but, not to insult, this is very hard to understand. Some detailed instruction of your process would be helpful. Also, can you use some punctuation, and spell check? It makes it easier on everyone.
