O-rings on the Opti driveshaft
Old Mar 19, 2005 | 02:37 PM
Robs97Z28's Avatar
What are the o-rings sealing? I removed the opti, so I could replace it. The o-rings were missing. Would this cause the lifters to be noisy, do to the lack of oil pressure?
Also, the opti driveshaft seal was leaking oil. I'm having a hard time finding a replacement on a saturday. Everywhere I call, is special order and won't be here until tuesday.
Old Mar 19, 2005 | 03:27 PM
Pasky's Avatar
Re: O-rings on the Opti driveshaft
It has 2 o-rings and doubt it would cause the lifters to be noisy. It would just make a small leak into the timing cover.
Old Mar 19, 2005 | 03:39 PM
Robs97Z28's Avatar
the new opti has 2 o-rings, but the old opti-crap has none. which, is leaking!
Old Mar 19, 2005 | 07:12 PM
Robs97Z28's Avatar
So, nobody has any ideas what the o-rings are for?
Old Mar 19, 2005 | 07:49 PM
They are not for oil control or sealing. As far as I can tell, they are only there to stabilize the shaft.
Old Mar 19, 2005 | 08:01 PM
Robs97Z28's Avatar
Thanks, Rob..
Old Mar 19, 2005 | 10:05 PM
NOMAD's Avatar
Correcto rob
The o rings matter nothing for sealing as they dip into a hole in the camshat that goes nowhere. They are simpley there for the stability control of the opti. Any o ring that will resist oil and temps will work fine. I've found them at lowes and other hardware stores.
-Shannon
Old Mar 20, 2005 | 10:40 AM
Robs97Z28's Avatar
Cool, now I need to figure out why the lifters are noisy. I hve had an oil leak and noisy lifters, all in the same week. Had to speical order a new opti drive seal, it won't be here until tuesday. Planning on pulling the covers today, hoping to find a loose rocker.
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
asilomar244
Jul 12, 2015 05:53 AM
