o rings on end of opti shaft broke off, does this matter
Old Jun 14, 2003 | 12:20 AM
D James's Avatar
I had to repull my opti to replace all the seals on the timing chain cover so they won't leak anytime soon since I was in there to replace my large oil leaking water pump seal, anyway after taking off the opti I touched the end of the shaft and the plastic or rubber o rings on the end of it just fell into pieces. This is the part that slides into the cam hole, I guess they lock it into place and keep it from moving around. Now I'm wondering if I should stick it back in there without any rings or go to either the hardware store for some rubber o rings or try and get GM ones, if they sell them. I really don't want to spend any more money, but I'm sure the opti is on borrowed time so I don't want to take chances and fry the thing cause I didn't spend a few extra bucks. Anyone have this problem or a solution?
Old Jun 14, 2003 | 01:28 AM
Mike454SS's Avatar
I know you don't want to spend money...but O-Rings are very cheap...they're there to keep the opti centered on the camshaft...replace them before you put it back together.
Old Jun 14, 2003 | 11:26 AM
97 SLP Company Car's Avatar
o-rings
Ive got two new ones I'll give you.I work in livionia so pm me and I'll get with you.
oldschool
Feb 9, 2016 09:21 PM
grabbem88
Mar 18, 2015 01:25 PM
dbrockma
Feb 16, 2015 02:56 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
