NSA or SA rockers??
NSA or SA rockers??
I've got most bolt ons and am planning on doing a 1.6RR upgrade. My question is if I should go non-self aligning or self aligning? I've heard that with high lift cams you should go NSA. I do not plan on doing a cam for a long time and if I do, it probably won't be a very aggressive cam. Also, what is the significance of the different stud sizes and which is better? Thanks.
If your goals for the car are fairly conservative, then self-aligning rockers with the stock 3/8" studs will do the job. I know some people will say, 'put in all the good stuff now, so you won't have to re-do it later," but the self-aligning rockers and stock studs do pretty well, depending on how radical a cam you will use down the road.
The NSA rockers will require the installation of pushrod guideplates and you will have to replace all your pushrods with hardened ones. This equipment handles very high revs better than the stock stuff.
The reason for 7/16" studs is that they are larger in diameter and stiffer, for more consistent and reliable valve train operation at very high revs or with very high spring pressures.
This is all good hardware, of course, but maybe overkill for an engine with a "not very agressive" cam.
For your current goals, a set of 3/8 stud SA rockers should be fine. Even if you upgrade to a very mild cam, those rockers will still tolerate it. I would probably consider upgrading the valve springs though while you are at it.
