NSA or SA rockers??
Old Dec 17, 2006 | 08:23 PM
arklie's Avatar
NSA or SA rockers??
I've got most bolt ons and am planning on doing a 1.6RR upgrade. My question is if I should go non-self aligning or self aligning? I've heard that with high lift cams you should go NSA. I do not plan on doing a cam for a long time and if I do, it probably won't be a very aggressive cam. Also, what is the significance of the different stud sizes and which is better? Thanks.
Old Dec 17, 2006 | 08:52 PM
Red96Lt1's Avatar
Wow, I was about to post the same thing. I'm guessing you have to pull the intake if you were to put in NSA. Also what is factory?
Old Dec 17, 2006 | 09:01 PM
speed_demon24's Avatar
What would NSA to SA rockers have to do with pulling the manifold.
Old Dec 17, 2006 | 10:02 PM
T/A-Bob's Avatar
If your goals for the car are fairly conservative, then self-aligning rockers with the stock 3/8" studs will do the job. I know some people will say, 'put in all the good stuff now, so you won't have to re-do it later," but the self-aligning rockers and stock studs do pretty well, depending on how radical a cam you will use down the road.
The NSA rockers will require the installation of pushrod guideplates and you will have to replace all your pushrods with hardened ones. This equipment handles very high revs better than the stock stuff.
The reason for 7/16" studs is that they are larger in diameter and stiffer, for more consistent and reliable valve train operation at very high revs or with very high spring pressures.
This is all good hardware, of course, but maybe overkill for an engine with a "not very agressive" cam.
Old Dec 17, 2006 | 10:13 PM
Javier97Z28's Avatar
Moderator
+3241342124214
Old Dec 18, 2006 | 11:50 AM
2000GTP's Avatar
For your current goals, a set of 3/8 stud SA rockers should be fine. Even if you upgrade to a very mild cam, those rockers will still tolerate it. I would probably consider upgrading the valve springs though while you are at it.
Old Dec 18, 2006 | 01:07 PM
69gto96z's Avatar
Do you have to pull the manifold to install NSA rockers? I have never heard that before.
Old Dec 18, 2006 | 01:09 PM
2000GTP's Avatar
Nope.
Old Dec 18, 2006 | 01:11 PM
69gto96z's Avatar
Awesome, thanks for clearing that up for me.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
