Now what?
Old Apr 13, 2021 | 06:35 AM
  #46
scope513's Avatar
Re: Now what?
Soldered radio connections.
Old Apr 13, 2021 | 12:09 PM
  #47
Gtpguy's Avatar
Re: Now what?
Did you get it running?
Old Apr 13, 2021 | 07:31 PM
  #48
scope513's Avatar
Re: Now what?
Still have to get it all connected, probably wont get to it until the weekend.
Old Apr 13, 2021 | 08:48 PM
  #49
1994-LT1-Eric's Avatar
Re: Now what?
Nice work 💪
Old Apr 14, 2021 | 05:10 PM
  #50
scope513's Avatar
Re: Now what?
Does anyone know where the security led goes? It went into the aftermarket alarm I took out, but where is stock location?
Old Apr 26, 2021 | 08:50 AM
  #51
scope513's Avatar
Re: Now what?
Update- finally got car to turn over but no start. Have to check for spark, if no spark I may have put opti on wrong. If just changing opti does it have to be at TDC? Also while I'm down there with car being 150k: 1- should I replace timing set 2- How to tell if pistons are damaged (curiosity)?
Old Apr 26, 2021 | 09:39 AM
  #52
Re: Now what?
Even if the Opti is indexed incorrectly, should still have spark. It would be out of time and run poorly, or maybe not start at all. As long as the cam dowel pin is in the correct hole, it is installed correctly. Did you check for spark at the Opti end of the coil wire, as well as at the cylinders?
http://shbox.com/1/opti_back.jpg
Without reading the old posts, is this a new Opti, or just reinstalling the old one? What brand?
Check for 1-4 volts on the white wire to pin B on the ICM. Use Shoebox's guide:
4th Gen LT1 F-body Tech Articles
If you don’t have voltage on the white wire at the ICM, proceed to the next part of the procedure to see if you have the correct voltage at the Opti harness connector.
Old Apr 28, 2021 | 02:27 PM
  #53
scope513's Avatar
Re: Now what?
Checking for spark at coil today, everything turned on electrical and starter cranked engine the other night. Opti is new, from petris which loctites the screws and and uses the Mitsubishi sensor. So today, 1 check for spark at coil. 2 check for spark at each cylinder. 3 check voltages at ICM and opti harness from links. Also check ignition fuse.
Old Apr 28, 2021 | 02:29 PM
  #54
scope513's Avatar
Re: Now what?
Is there a way to hook up a starter switch to the lt1 so I can do it on my own? If so how?
Old Apr 30, 2021 | 06:43 PM
  #55
DrewHMS97SS's Avatar
Re: Now what?
Do you mean so you can turn the engine over while working on the car?
Amazon Amazon
Old May 1, 2021 | 07:24 AM
  #56
scope513's Avatar
Re: Now what?
Yes, but where do I connect? I have one but not sure if this car is picky.
Old May 1, 2021 | 08:24 AM
  #57
Re: Now what?
Connect the leads from your remote starter switch to the terminals with the two arrows in this pic. It won't do anything but crank the engine without the key ON.
Old May 1, 2021 | 11:25 AM
  #58
scope513's Avatar
Re: Now what?
Thank ya much.
Old May 1, 2021 | 04:44 PM
  #59
scope513's Avatar
Re: Now what?
I think I found the culprit.
Old May 1, 2021 | 04:45 PM
  #60
scope513's Avatar
Re: Now what?
Pcm to ground?
