now what?
Old Jul 28, 2003 | 10:15 PM
Bobbys_97_Z28's Avatar
Angry now what?
ok since i got the car its been giving me a p1441 code...i have changed the evap check valve in the back and the hoses going to it...i hve change te solinoid on the engine and the hoses going to it and to the thottle body? now what? and yes i click my gas cap every time i get gas and no i do not put gas in it with my car running....im gong crazy!
Old Jul 28, 2003 | 10:38 PM
Question also
also...the solinoid on the engine, that goes to a swich...with the house...well when i take off the hose from the one side of the switch and i put my finger on it, it is sucking is this supposed to suck all the time?? cuz maybe its that switch? i dunno...im askin the pros thats why im here! come on guys
Old Jul 28, 2003 | 11:25 PM
There is a "flow detection" switch on the OBD-II's (96/97). That switch is located between the EEC purge solenoid and the throttle body. Since the solenoid is the item that stops the flow during "non-purge", there will be vacuum anywhere from the TB to the EEC purge solenoid... it will be "sucking". You need to check for leakage on the other side of the purge solenoid... by removing the line that comes from the canister. That is where there should be no vacuum when the solenoid is not energised.
If you have verified that the solenoid is closing completely, and that there are no vacuum leaks in the hoses between the solenoid-switch-TB, you might want to check the flow detection switch and see if it is faulty. I do recall a couple a posts from a while back where people chased this problem down and were never able to find where the code was coming from.
Old Jul 31, 2003 | 10:16 AM
guesss what
i was at work ...checking out the hoses on the sol for the eec...and it looks to me that that hoses were reversed and maybe thats why my car was getting the code p1441...the "S" shaped hose was on top and the one from the tb was on the bottom...
its supposed to be "S" on the BOTTOM and STRAIGHT TUBE FROM TB ON TOP!!!! its been a couple days and no evap codes so i think i might be good to go....i still have a slight hesitation though
Old Jul 31, 2003 | 10:41 AM
I have posted before that if the hoses were swapped, you will get the code.
