Cranking, not starting. What else could it be besides opti?
Old Jul 25, 2003 | 05:56 PM
Durbn4duke's Avatar
I changed my anti-freeze,..... yes i know. and well i dont think i got anything wet, well the car started up and got me about 2 miles, then i went in the food joint, left the car running, came out and the car was dead. It crank but never started back up. i have no spark in the plugs or coil. i hooked up my old coil and it still dont work, so its not the coil. How often do the ignition modules go out? What could i have done? I really dont wanna change the opti again, it has 6,000 miles on it, and 2 years old. I'll appriciate any responses to this.
Old Jul 25, 2003 | 06:33 PM
TobyZ28's Avatar
Do you know if it overheated while idling?
Old Jul 25, 2003 | 06:41 PM
buelldevil's Avatar
Should not be the ignition, if it was, it would be copletelly dead.
Old Jul 25, 2003 | 06:44 PM
Do you have power to the coil? Have you checked fuses?
Old Jul 25, 2003 | 06:48 PM
Carlos01SS's Avatar
My car died on me once, I was driving out for a lunch date, crossed the intersection, and it flat-out-died. I tried to start it over & over, it would sound like it turns over, but dead. It ended up being the Ignition Control Module(ICM), had it scoped by the dealer, they charged me 300 bucks to replace it, this included the scope charge. My car had about 100K miles on it.
Old Jul 25, 2003 | 10:19 PM
555PREZ's Avatar
I'm having a similar problem right now. Last week I changed my stock coil to an accel and everything was working good until tonight. The car will crank but just doesn't want to start up. I'm pulling my hair trying to think of something but I'm not having much luck coming up with a solution.
Old Jul 25, 2003 | 10:26 PM
Check for spark, first. Some new coils die prematurely.
Old Jul 25, 2003 | 10:59 PM
555PREZ's Avatar
No spark
Old Jul 25, 2003 | 11:09 PM
ibanez6rg's Avatar
4 things:
Spark - Fuel - Air - Compression
Old Jul 26, 2003 | 05:25 PM
Durbn4duke's Avatar
I am not getting spark from the plugs or the coil. i hooked up my old coil and still got nothing, so i kinda weeded out it being the coil. Where is the icm at? How do i test that? I am getting fuel, the pump wines when i turn the key. Any opinions?
Old Jul 26, 2003 | 05:28 PM
555PREZ's Avatar
Exactly the same thing as me, I've tried two coils and still nothing. Shoebox has a pic of the ICM
Old Jul 27, 2003 | 12:16 AM
MentalCaseOne's Avatar
Food for thought... when my alarm goes off it shutts off the fuel... My car still crancks though.... have you checked your fuel pump/pressure??
Old Jul 27, 2003 | 12:31 AM
94GrayV6's Avatar
That definitely sounds like the ICM to me. My car died on the highway one night and absolutely would not start even though it cranked fine. They are pretty cheap, so its no biggie.
Here's one
Old Jul 27, 2003 | 01:46 AM
Z95m6's Avatar
i think the ICM too. I heard that autozone can test them for you.
Old Jul 27, 2003 | 07:52 AM
^^^my first post. Did you ever do this? I hope you are not going to run out and buy parts without doing this first.
