And now I'm [upset]!
Old Apr 28, 2006 | 04:00 AM
raxxus's Avatar
Angry And now I'm [upset]!
My car would not start for 2 weeks, no spark at all. I finally figured out it out ( with shoebox's website) that it was the ICM, and bam, fires right up after I replace it! Runs like a champ for a day or two, and now when it's under load ( read: 1500 or so rpm in 4th gear) and I give it gas, it starts chugging really bad? Almost like it has a dead cylinder? If I floor it in first going 5 or so mph, it runs perfect. And it seems to idle really well too. It just started doing this on my way home from dropping some people off tonite ( the car was warm ), so I'm going to test it tomorrow right away when its cold. Anyone have any ideas?
Old Apr 28, 2006 | 07:24 AM
wrd1972's Avatar
Re: And now I'm #$%@ing pissed!
Replace the plugs, they might be fouled.
The plug wires, they may be arcing.
Definitely sounds like ignition or fuel pressure.
Old Apr 28, 2006 | 02:17 PM
raxxus's Avatar
Re: And now I'm [upset]!
Interestingly enough, when I started it this morning, it runs perfect. I took it around the apartment complex 2 times, putting it into heavy load with 3rd, 4th, and 5th gear and flooring it, and it responds normally. I'm going to inspect my spark plug wires ( I had one burn up on me because of the headers ). I will report as soon as I figure out the solution!
Note: I'm going to use the ICM cooling mod also, to see if that has any positive effects.
cmsmith
Sep 14, 2015 09:25 PM
NewsBot
Dec 24, 2014 11:05 PM
ReznorZ28
45
Dec 29, 2002 12:28 AM
