Now how did that happen
Old Nov 15, 2004 | 07:55 AM
Eff's Avatar
Eff
I realize this isn't entirely engine related. but bare with me.
I was pulling off my intake yesterday, seperating it between the MAF and the
intake elbo. And there in my stock MAF (with the honeycomb still in it), calmly sitting on the element was a live wasp.
How did it get there? How is it that it was still around in the middle of november, and how was it able to overcome the engine vacuum?
Old Nov 15, 2004 | 11:24 AM
BoobSter-lt1-z's Avatar
Re: Now how did that happen
Wow!!....thats Crazy ...
You Had Your Filter On Right???
Did You Leave The Car Unattended While You Were Removing The Parts???? I Dont Know Why That Wasp Wasnt Dead. I Am Trying To Wonder How It Got In There And How Long Its Been In There For. Man I Am Puzzled.....
Old Nov 15, 2004 | 11:30 AM
WS Sick's Avatar
It possibly came in through the Airpump route. They stick around but move very slowly when cold, they actually hibernate.
Old Nov 15, 2004 | 11:34 AM
crash4cyl's Avatar
maybe he said "warmth, I'm sleeping there!!" and got sucked in the intake some how??? Maybe the airpump?? Kinda like the 'ole cat under the hood story you've always heard about!!
Chris
Old Nov 15, 2004 | 12:00 PM
but there is no air pump before the intake or MAF...isnt the air pump after all of these components..../
THIS BRINGS ME TO A QUESTION, WHEN YOU TURN THE CAR ON AND THE AIR PUMP COMES ON, THE INTAKE SUCKS THE AIR THROUGH BECAUSE OF THE AIR PUMP, BUT HOW DOES THIS PROCESS WORK THOUGH????
Old Nov 15, 2004 | 12:56 PM
Mtrhds94Z's Avatar
AIR pump takes air FROM the intake tract [before the MAF]and pumps it into the exhaust manifolds..
Old Nov 15, 2004 | 01:06 PM
so it sucks air through the engine so that suction begins at the intake through the MAF and into the throttle body and into the manifold...right?
Old Nov 15, 2004 | 01:14 PM
WS Sick's Avatar
Huh?
Old Nov 15, 2004 | 01:45 PM
madwolf's Avatar
I'd check all the ducting/filter, etc. You probably have a hole somewhere.
Old Nov 15, 2004 | 02:59 PM
i AM JUST TRYING TO FIGURE OUT STEP BY STEP HOW THIS AIR PUMP WORKS BUT ILL JUST LOCATE THIS ON THE CAR AND SOMEHOW FIGURE IT OUT
Old Nov 15, 2004 | 06:30 PM
Mtrhds94Z's Avatar
No.. think of the AIR pump as 'bypassing' the engine intake tract [ the ENGINE is an 'air pump' also, so don't get confused here, manifold vacuum, vacuum at the MAF, TB, and intake are generated by the engine itself....]
The AIR pump pulls air from the intake before the MAF[from the CAI elbow if you have one] and then it pumps thru the AIR pump then it goes thru 2 pipes/check valves/hoses to the exhaust manifolds.. [ bypassing the engine with SOME air.. the engine still has the same manifold vacuum tho] that's those 2 pipes you see sticking up out of the tops of the manifolds..
The purpose is to provide more air for the catalytic converter to help heat it up [it needs to be hot to work] this only runs a few minutes on a cold start..
Hope this clears it up for you...
Old Nov 18, 2004 | 03:03 PM
Eff's Avatar
Eff
Well, the air pump was sealed off long ago, and I was watching the car the entire time. but had been running it recently without the air filter.
however that still doesn't explain how he got through the MAF or what he was doing at my house in november.
Old Nov 18, 2004 | 05:33 PM
1 Nasty Bird's Avatar
Watch out there may be a nest under the hood or behind the fenders. No BS!!! I know a couple people that had wasps build nests under the fender where you cant get at. Id keep a can or two of wasp killer around for a lil while. Them suckers can get mean. Have you ever noticed em around your car before??
Old Nov 18, 2004 | 05:48 PM
you dont wanna have to be doing this!
thought you had underhood bee problems?
Old Dec 17, 2004 | 04:57 PM
Eff's Avatar
Eff
hmmmm....... not in November.
Novo
Jun 14, 2016 02:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
