Not happy with the new H/C times
Old Mar 21, 2005 | 10:37 AM
  #16
Re: Not happy with the new H/C times
To evaluate the MAP at WOT, you need to compare it with the barometric pressure. Did you also get that off the data log? Do they print it on the timeslip? Is there any possibility that there was a "low pressure" front in the area (usually accompanied by rain, so not likely)? If not, the standard barometer at 1,200-ft is about 97kPa, so you are losing 7kPa in the intake track. Thats about 2"Hg, and that seems like a lot to lose. Anything in the intake track could be contributing to the pressure loss. The TB would be a contributor.
Old Mar 21, 2005 | 11:22 AM
  #17
Deenasty's Avatar
Fred, if the barometer is printed on a timeslip, how do you calculate kPa, better yet what is "kPa" for us beginners? And how do you go about reading the kPa, Datalog? Care to elaborate to me. Thanks!
Old Mar 21, 2005 | 01:31 PM
  #18
The "pascal" is a metric system measure of pressure. 100 kPa (kilo pascals) = 1 bar = 14.5psia = 29.53"Hg. 14.5psia is the "standard" metric system atmospheric pressure. In the English system, "one atmosphere" = 14.7psia = 29.92"Hg = 101.4kPa.
You can read the barometer and the MAP from your PCM with a scanner. You can measure vacuum with a vacuum gauge, read the barometer, and calculate MAP if you don't have a scanner.
MAP + Vacuum = Barometer
Barometer - MAP = Vacuum
Old Mar 21, 2005 | 04:31 PM
  #19
jchevy's Avatar
Im not sure if the datalog shows barometer reading, i will check that when i get home. The logged runs i have arent from the the night i raced, not that my track gives weather conditions anyway.
Old Mar 26, 2005 | 03:41 PM
  #20
jchevy's Avatar
Discovered some major problems on the dyno today.
My A/F was 18:1. The tuner said he had never seen a car that lean before.
I put a fuel gauge on it and at idle i have 40 psi, but WOT it drops to about 20psi. After a new filter it still drops to about 30psi.
What do you think, pump or regulator??? WHich to replace first?
Car put down 318hp and 350tq. It was a dynojet and those numbers are corrected.
Old Mar 26, 2005 | 03:59 PM
  #21
SStrokerAce's Avatar
God dam! 18:1 and no fuel pressure at WOT!!!! Well I think you found the problem.
Bret
Old Mar 26, 2005 | 04:18 PM
  #22
jchevy's Avatar
Yeah, im going to put a fuel pump in it, verify the pressure and try to get back to the dyno maybe next saturday.
Im glad i didnt wait to long to get to the dyno.
Old Mar 26, 2005 | 07:18 PM
  #23
got_hp?'s Avatar
Originally Posted by jchevy
Also, my plugs are are NGK TR-6s.
not sure if anyone mentioned this in the thread, but arent those TR6's for nitrous?
ive read people with nitrous setups say they lost power n/a with the TR6 plugs.
i think the TR55 is better for n/a.
Old Mar 26, 2005 | 09:57 PM
  #24
Deenasty's Avatar
yup...I did also. We had to shoot about 4 degrees more of timing just to get the cylinder to proper operating temp. Swapped to the Tr55, and pulled the 4 degrees back out, and made the same power that the TR6 with +4 did.
Old Apr 2, 2005 | 04:50 PM
  #25
jchevy's Avatar
update
http://web.camaross.com/forums/showthread.php?t=354880
Feffman
Oct 9, 2015 05:42 AM
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
ChrisFrez
Jan 4, 2015 08:43 AM
