is this normal?(gas consumption question)
Old Apr 3, 2003 | 02:11 PM
Zack's Avatar
I filled up some gas last night, and I reset the Speedometer. after just 7 miles of driving, the needle had moved noticably. when I filled it up, I had about 10 gallons in there, so I'm gonna keep track of it. I justput my car on a lift in auto class and my teacher pointed out the original fuel filter. the car has 83k miles on it, so would replacing that improve MPG?
Old Apr 3, 2003 | 02:14 PM
CamaroRob97's Avatar
yeah if its never been changed, injectors could also be clogged up some, if u have a stat lower than 195 that could be part of gas consumption EGR valve if its old and all carboned up could alos hve something to do with it as could ur cats.
Old Apr 3, 2003 | 02:36 PM
Thebeast431's Avatar
If you are hitting your brakes when you check your gauge, the gas probably shifted to the front of the tank giving you a different gas reading, or if you checked you fuel gauge while pressing the accelerator, the gas could of moved to the back of the tank and messed up the gauge. The LT1 gas tank is in the shape of a " V " so a half tank on the guage is really 1/3 or maybe even a 1/4. If you think its bad gas mileage, your O2 sensors are ready to be replaced and will make a hell of a difference.
Travis
Old Apr 3, 2003 | 02:49 PM
He is going to have a thermostat lower than 195º, since the stock one is 180º.
Old Apr 3, 2003 | 08:04 PM
Zack's Avatar
thanks for the responses. My auto teacher told me we can scan the computer next week for any codes.
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Noenav
Dec 6, 2014 07:35 PM
simple
Aug 11, 2002 11:56 AM
