Nonvented opti + H/C set up options.
Old Jan 25, 2008 | 02:30 PM
94NDTA's Avatar
I have a 94 LT1, and I am trying to get it underway with an LE2 set up. HOWEVER, I am running into the problem of the timing chain. The only aftermarket ones that work with 94's are $500 a set. The other option is to upgrade to a vented opti, purchase the wiring harness, vacuum harness, Timing cover, and EWP, costing ~$500. One last option is an LT4 ED timing set , but I have heard bad things about these.
Are there any other options?
Old Jan 25, 2008 | 02:47 PM
sleeper94z28's Avatar
dont forget about the pin that comes out of the cam must be longer to drive the newer opti, personally I would buy the cloyes set from orielly's and get a better chain and call it a day. Since you probally arent running a really high rpm it would work, but I would understand why you wanted to upgrade.
Old Jan 25, 2008 | 02:54 PM
94NDTA's Avatar
Cloyes won't work on a 94 from what I heard.
It will be spinning to ~6400 rpm.
Old Jan 25, 2008 | 03:35 PM
The LT4 ED is not an option in itself. It also requires the vented opti conversion (but you would not need an electric water pump).
Old Jan 25, 2008 | 03:54 PM
Originally Posted by 94NDTA
... One last option is an LT4 ED timing set , but I have heard bad things about these.
My LT4 ED timing set has been fine for 8 years with a heavy spring solid roller cam. And as Shoebox noted, you need to do the vented Opti conversion with the LT4 ED.
HectorM52
Jul 30, 2017 11:46 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Bignasty85
Mar 3, 2015 04:05 PM
