Nominal operating temperature? Is this too hot?
Old Jun 17, 2004 | 10:45 PM
  #16
Originally posted by warwickbass
Haha, well, it's already in there. I THINK it was the longer design. I think the fans are supposed to come on at 226, how can I reprogram them to come on at 180 or so?
The most elegant method is to have the settings changed in the computer.
Old Jun 18, 2004 | 05:59 PM
  #17
warwickbass's Avatar
Haha, but I have no means of doing it myself. I called two dealerships and asked the guys about what temperature my car should be running at during the summer. Both said 210. The temp stays between the very middle line and the line after it. I know I've said this before, but should I worry about this or not?
Old Jun 18, 2004 | 06:51 PM
  #18
Kraest's Avatar
Retired
Personally, I don't enjoy seeing a high-compression motor, like the LT1 run that high of a temp.
There's a do-it-yourself on Brent Franker's site that tells you how to jump the fan relays so that they always stay on.
Mike
Old Jun 18, 2004 | 07:10 PM
  #19
I'd rather just program the fans to come on at 200, but if they were on all the time, how would that affect everything? Performance, et cetera.
Old Jun 18, 2004 | 07:14 PM
  #20
simple's Avatar
i think the lowest you can program the fans to turn on in the pcm is 190*....
fyi, i have a stock thermo, CSI, fans at 190 and it will barely rise over the 1st 1/4 mark on the guage (CSI didnt change the temp at all, its the same as before it got put on)
i wouldnt worry about your temp too much as long as the fans kick on and knock it back down when they are suppose to
if it doesnt drop when the fans come on thats when i'd worry
but it is nice to have the cooler temps in there!
Old Jun 18, 2004 | 07:30 PM
  #21
I know, where's that site and how would that affect peformance, gas mileage, etc.?
Old Jun 18, 2004 | 08:56 PM
  #22
96WhiteZ28's Avatar
My temp doesn't really go past 1/4 much and it was 85 degrees here and humid today. Remember there are two fans. One that goes on when it reaches a certain temp i think 226 was mentioned and the other fan goes on when you turn your A/C on. My firebird had a fan broken and i would actually drive with the A/C on all the time to keep it at 1/2 and if i turned it off it was a pinch over 3/4 but never red.
  #23
96WhiteZ28's Avatar
Old Jun 19, 2004 | 04:25 PM
  #24
Hmm..My A/C doesn't work though. And my fans turn on and drop the temperature, so, that's good.
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
