Nobody ever discussed the SLP clutch pedal feel, over stock, in detail!?!?!?!?
Old Jun 29, 2003 | 09:12 AM
SSCamaro's Avatar
I am about to put in a replacement clutch for my car. The stock unit, with the beveled fingers, was quite suprisingly hard when I started driving it. I got used to it though over time. Now, I am thinking of the SLP setup, but, since it has higher clammping force, I am scared that it will make the pedal that much harder to push. Anything harder than what I had would really suck!!
Can you all, that have them, explain the differance in feeling over a stock unit? Thanks.
Old Jun 29, 2003 | 06:25 PM
97FormulaWS-6's Avatar
when I replaced my 70K stock clutch with the LT4/SLP clutch I felt almost no difference in the pedal... they were just about identical, although the friction point was about 1" difference in the pedal.
Old Jun 30, 2003 | 03:33 AM
HungryT/A's Avatar
I do NOT have the SLP clutch, but I hear it is pretty much same as stock. Our cars have hydraulic clutches, so pedal "hardness" can be affected by the master/slave cylinders. When my slave cylinder was cleaned up, it became very-very light.
Old Jun 30, 2003 | 05:29 AM
mineralwater's Avatar
i have the slp clutch, and the pedal feel is same as stock.
although, as previously mentioned, the friction point is a little bit closer to the floor. Might be that way because my old stock clutch was slipping like mad, though..
Old Jul 2, 2003 | 09:51 PM
SSCamaro's Avatar
Just put in an autozone replacement with the flat fingers (not the LT4 clutch though).
Pedal feels a tiny wee bit softer but I did replace the slave cylinder.................... co-winkydink??? Clutch also disengages a wee bit closer to the floor than the last, but not much. Tiz a bit grabber and that could be due to the rough surface of the flywheel which makes it a little grabbier than it used to be.
All in all, I am happy with it, especially after the hell I went through.
Old Jul 2, 2003 | 10:53 PM
Z95m6's Avatar
I have the SLP unit and it feels exactly the same as stock. The autozone version i have heard is the LT4 PP too. I have heard valeo the only maker of our pressure plates only make 2 models, the stocker with ridged fingers, and the LT4 with flat fingers.
Old Jul 2, 2003 | 10:58 PM
turbo_Z's Avatar
LT4 pp/LT1 disc here and the pedal feel is just the same as stock. it does grab a closer to the floor b/c my old one slipped so bad off idle. but if it werent for my changing the clutch myself.. .i wouldnt have noticed the difference except for it starting to grab 1/2 way up or less than before where it grabbed right at the top.
Old Jul 3, 2003 | 12:00 AM
96LT14u2Nv's Avatar
i loved mine when it was a 6 speed. it almost feels the same. there is no real difference. it feels stronger but it isnt much harder to push in. it is the best street clutch i have tried. i hight reccomend it.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Jan 30, 2015 11:08 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
