NO start!!!!very weird, inside!!!!
Old Feb 16, 2004 | 12:10 AM
96LT14u2Nv's Avatar
alright, a few weeks ago my starter went out (kept running after car was started) so i replaced it with a starter from autozone. car started up fine 6 times. go to get gas, and no start. push started it, took it home and took starter off and re-installed after checking everything. started 4 times and did the same thing. thought mabey the starter was a dud so i sent it back and ordered a heavy duty Powermaster and put it on. started up 3 times and then a no start. this time it had no power to the gauges, and would not take a push start (popping clutch to start). took new starter back out and checked all grounds, re-instaled. now have power to the gauges but still only a few starts b4 it wont start anymore. and when it would start it would drag really bad while cranking. saw that the voltage was dropping when starting so i went up and got a new optima battery. tried that and STILL a no-go. anyone have any ideas? i am going crazy here!!!!!!
Old Feb 16, 2004 | 07:23 PM
slopokrodrigez's Avatar
You have a bad connection. Which ones have you checked so far?
Old Feb 16, 2004 | 10:34 PM
96LT14u2Nv's Avatar
checked the one behind the AC, the one on the starter. and the one from the battery.
TTT
Old Feb 17, 2004 | 05:13 AM
Now you want to check the ones that are missed all the time. The frame has a ground and the engine has a ground. Take em off clean the cables and the spots they hook to real well, reinstall them and then do a final check.
With someone cranking the engine, see that the voltage across the battery does not go below 11V.
With the engine running be sure the voltage across the battery is close to 14 volts. If not you may have a bad alternator.
Let us know what you find out.
Old Feb 17, 2004 | 07:38 AM
Since you mentioned no power to the gauges once (not sure if you had power elsewhere), you might have a faulty/worn out ignition switch. Replacement instructions on my Tech Page.
Magenta_Hearts
Mar 25, 2015 10:24 AM
Deadbolt24
Jan 19, 2015 01:29 PM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
jj71787
Dec 30, 2014 02:15 PM
